1. Jade Johnston89's Avatar
    hey everyone
    Im hoping someone is able to help me. My samsung s3 was stuck on the samsung screen and kept restarting. i have gone into recovery mode and the message "failed to mount efs" has come up. How do i fix this ?? Please help.
    Thank you
    Jade
    04-04-2014 03:57 PM
  2. Jade Johnston89's Avatar
    I have all my daughters photos on my phone i really dont want to loose them all
    04-04-2014 04:09 PM
  3. GSDer's Avatar
    /efs is a partition on the phone's internal memory that is used to store important information (like the IMEI - the unique serial number of the phone). It's not accessible to a normal user and shouldn't get corrupted under regular use.
    With all of that said, you're apparently having such a problem, but I'm pretty sure that simply rewriting the firmware isn't going to fix this - that partition isn't included in the stock firmware files.
    I don't have a solution for you other than to take it in to your local carrier store. Their solution is unlikely to result in your data being saved. Sorry.
    You may get a better answer over on XDA (where they mess with stuff like that), or you may get lucky with a Google search.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    04-05-2014 12:16 AM
  1. How to stop apps from running?
    By cnyjim in forum Verizon Samsung Galaxy S4
    Last Post: 08-28-2015, 07:47 PM
  2. Sprint LG G2: What did we NOT get with the update?
    By Jimmy Gillentine in forum Sprint LG G2
    Last Post: 04-13-2014, 06:15 PM
  3. Is it possible to BOGO and keep unlimited data?
    By DreamSTi in forum Samsung Galaxy S5
    Last Post: 04-07-2014, 10:41 AM
  4. Replies: 8
    Last Post: 04-05-2014, 02:59 PM
  5. What do you guys think?
    By rrballer11 in forum Google Nexus 5
    Last Post: 04-04-2014, 06:36 PM
