Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Default Galaxy S3: Battery draining while charging **
    Hello, this is my first time creating a post, I know that this is a reliable website to be in therefore I will state what is wrong.
    Lately, my Samsung galaxy S3 has been dying very quickly. Also, while my phone is charging, the battery is still draining. I tried turning it off and I gave it half an hour, turned it on and it went up to 35%. It is currently still charging and its on 31%. Anyone have an idea on what the issue could be?
  2. #2
    Default Re: Galaxy S3: Battery draining while charging **
    I never encountered this problem on my S3 but I will try to help you. Here are some suggestions... How long do you own your S3?
  3. #3
    Probably the battery going bad. They do that.
    I'm very happy with a RAVpower 2250mah battery i have.
  4. #4
    Quote Originally Posted by xtopic1 View Post
    Welcome to the forums!
    This sounds about right - with the phone completely off it should take no more than two hours to fully charge.
    Have you tried booting into Safe mode http://support.verizonwireless.com/s...ase.html/59242 and charging it to see if the same drain occurs?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Hehe. I figured out the problem.
    The charger is broken. It's upsetting, though. My charger constantly breaks. Like I have it plugged in and it doesn't even say it's charging. I don't know how many times do I have to buy a new charger!
  6. #6
    i got S4 and facing the same problem, battery drainage during charging... when i use USB CHARGING cable for charging it drains out the battery power? why is it so??
  7. #7
    I also have a galaxy 3. I just bought a new battery a few days ago due to mine swelling up. Even with the new battery my phone wont hold a charge for to long. Its mostly on the USB charge because the plug sucks and wont charge it. Even while its slowly charging I cant use it which is VERY disappointing. I've even tried a few of those battery saving apps but I dont see a difference.
  8. #8
    Quote Originally Posted by John Anderson6 View Post
    If you're having problems with the micro-USB port perhaps you should consider a wireless charging solution?
    Or you could look at cleaning the micro-USB port. And maybe a few of the pins are mis-aligned - you can find a YouTube video on how to straighten them out. (Both of the previous steps should be done after you remove the battery.)
  9. #9
    Try a new cable!!!! Samsung cables aren't great, i did try a new one and it works wonders!!!!!! Try a new cable!!!
  10. #10
    Quote Originally Posted by GSDer View Post
    Welcome to the forums!If you're having problems with the micro-USB port perhaps you should consider a wireless charging solution?
    Okay, I have no clue why galaxies suck at battery power. This all has been happening to me too. I plug in my phone and it drains while charging. I power it off and turn it back on to see it only charged from 30%- 40%. How can Samsung fix this issue
  11. #11
    recently my Galaxy s3 mini is not charging at all - the battery is actually draining while plugged in!!!!!!!!!!!!!!! and it not recognizing my usb plug either !!!!!!!! my husband has the dame phone so we exchanged battery to see if it was the battery but it is not !!!!!!!!!!!!! can this be fixed or do i need a new phone .
  12. #12
    i am having the same problem - it is not the battery or the cable it is the actual port the charger or usb has to be plugged into - i know this becasue my husband has the same phone and we been exchange batteries to use and charge .................. how can i have this fix
  13. #13
    have you gotten it fixed my cell has the same issue
  14. #14
    I have a galaxy s4 and while plugged in if I use the phone for anything it drains. Is that normal I would think as long as it plugged in should be ok but I have tried 2 batteries and several cords and it does and did it with them all. Why is this? Thanks☺
  15. #15
    Do you know what the problem is yet?
  16. #16
    I have similar problem.
    I have 3 (three) Samsung Galaxy phones at home bought at different points in time, but all has the same Android code level (4.3). All of them started to have battery charging problems at the same time, let's say that all of them started about three weeks ago. I changed batteries, cables, chargers, but many times S3 'decides' not to charge and them are continuously draining battery while charging.
    It is very strange that all of them started to cause charging problems approximately at the same time. I've read articles about Samsung planned obsolescence, but it is difficult for me to accept this statement.
    Any idea how to fix such battery charging problems?
  17. #17
    Hi there i just joimed this thing to tell u im using a samsung galaxy s4 gt i9500 and im facing the same problemo....
    anyway here is the fix
    for ROOTED PHONE ONLY OK !!! IM NOT RESPONSIBLE FOR ANY DAMAGE THAT HAPPENS TO YOUR PHONES DATA OR ANY POSSIBLE PERSONAL DAMAGE OK!!! JUST MAKING THING CLEAR
    now use philipz touch and wipe ur dalvik memory cache what ever ... wipe ur dalvik and ull be fine
  18. #18
    And yea... wipe the cache too
  19. #19
    I had the same problem. I changed my samsung charger to LG charger. And now it charges faster then it used to. (:
  20. #20
    I'm having the same problem. Battery drains even when being charged. I have 2 wall chargers and a car charger. Same thing, even with new batteries. Does anyone know the fix? Is it the phone....this expensive phone is less than 2 years old. Clearly, buying new batteries wasn't the solution.
  21. #21
    Hi. This morning I had my S4 charging while being shut down and it reached 18% really fast. I unplugged as I went out. When I put it back to charge (the phone being on and I was using it my usual stuff at the same time, I noticed that the battery was draining although it was supposed to be charging. Changing the charger didn't result proper charging, it was still draining. The phone is less than a year old, maybe half a year and this was very sudden as it had charging finely before. Could the battery suddenly go bad like this? I would have thought it would do it gradually.
  22. #22
    I don't know if anyone will still see this, but I have a Galaxy Note and it is doing the same thing. I bought what I suspected to be a new battery online, but am thinking it is defective because it is even worse than the first one. My original battery took a good 12 hours to charge and last night, with the new battery, it went from 73% to DEAD! I have to power my tablet off and it still takes forever to charge.
  23. #23
    My phone has been lately draining battery while charging.. N I even formated my phone n its still the same.. Its charging slowly even when the phone is switched off. What should I do??
  24. #24
    I am having the same problem. I kept my phone on charge overnight and it only charged 72%. The other day I put it on charge and it said 15%, so I took it off charge and it suddenly said 8% so I put it back on charge again and then it suddenly said 1%? I have a battery safe app with boost your battery and it has antivirus etc. I just don't understand?
  25. #25
    I have this problem with all chargers and new original batteries. Extremely weird that it only works wiith samsung charger but old cable from sony xperia z ultra. Nothing else works.
  1. Any legitimate battery saver app?
    By Daermos in forum General News & Discussion
    Last Post: 02-23-2015, 10:12 PM
  2. How to Charge Batteries .....
    By vja4Him in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 04-09-2014, 06:55 AM
  3. How do you remove the Low Battery warning screen?
    By richtd in forum Samsung Galaxy S4
    Last Post: 04-06-2014, 07:05 PM
  4. Galaxy S4 battery issues?
    By KaI-El in forum General Help and How To
    Last Post: 04-06-2014, 04:26 PM
  5. How to fix my charging port and call issues
    By Emma Corbett in forum Samsung Galaxy S4 Active
    Last Post: 04-06-2014, 12:26 PM
