I skimmed through a bit of what the OTG USB is about, and from what I gather, it allows you to use your phone like a USB host. I went ahead and bought one, guessing that I will be able to connect its plug into my GSIII, then use the the USB slot to plug in my USB stick to transfer files.
Questions: Will it work? If yes, does it work both ways? Meaning, will I be able to transfer files from my phone to my USB, AND from my USB to my phone? Will I be able to open and view files on my USB without transferring them to my phone's storage?
Thanks in advance.
BTW: it's the "male micro-USB to female USB" kind, and my phone is not rooted.
Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
Thanks in advance.
