I have a used AT&T Samsung Galaxy S3 16GB (model SGH-1747) that I bought of the previous owner. I've been using it on Straight Talk's BYOP sim card program since December 2013 when I bought it, it was probably a year or so old already. The phone has always worked great. Then a few days ago I was riding my bike and it fell out of my pocket. It hit on both the upper right hand corner and lower right hand corner of the casing (on the silver trim edge), but thankfully the screen was intact without cracking or scratching.
When I got home I realized that the screen wouldn't turn on and I assumed the battery was dead so I switched it with the full battery from our other SG3. When the battery is put in, the phone vibrates, the screen shows the word "Samsung" and then switches to "Samsung Galaxy S III", then it goes black again. No matter how long I hold the power button nothing happens other than to repeat that process. I tried holding the Power button, Volume Up, and Home button at the same time - nothing. I tried again but using Volume DOWN - nothing. I tried holding both Volumes, Power, and Home - nothing. I've taken the battery out and smacked the side of the phone - repeatedly - on both my hand and the table - nothing....
I know the screen and digitizer are fine or the words "Samsung" and "Samsung Galaxy SIII" wouldn't come up. I know the phone vibrates, and sometimes when I put the phone on the charger I get the battery icon with the circle in the center of it, but it doesn't show it charging - so I know it is getting power. Obviously, I do not have a warranty either and so I can't just pop into AT&T, Straight Talk, or the Samsung store to have them fix it. Any suggestions on what to try? When I took the back off all the components look fine, and I am sure that none of the buttons are stuck. Thanks for any help you can offer, another phone just isn't in my budget right now!!
