Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By eric0668
    eric0668's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S3 Stuck On "Samsung" When Restarting After Factory Reset
    I have Googled and found many queries that talk about this. However most talk in terms of pros
    I am helping a friend of mine sell his S3. What is described above happened to his phone. Stuck on Samsung
    We have done a battery pull. A battery pull, restart with Up, Power, Home AND Down, Power, Home, and UP & Down, Power, Home to no avail
    I am not sure when we chose factory reset why it took us to ...what is it called? ...the Recovery page or something? We selected Factory Reset, and it restarted after a bit and we are where we are now
    I read something about a program Odin, which I downloaded. Something about the factory ROM. I have no idea where to get that. The phone is not rooted
    If anyone could help me, in the most basic terms, I would be very grateful
    Thank You
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S3 Stuck On "Samsung" When Restarting After Factory Reset
    You should be able to find the firmware here - select your device in the drop-down list in the upper left corner, then download the latest version.
    Does the phone boot into Download (aka Odin) mode? (That's Volume Down + Home + Power.)
    If you need to know how to use Odin you can look in any of the rooting sub-forums for instructions.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    eric0668's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The phone won't do anything. Won't boot into Odin. Just sits there with Samsung on screens
    As far as the firmware, the T-Mobile Galaxy S3 T-999 is not listed
  4. #4
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by eric0668 View Post
    Does the phone begin to boot up by itself if you take the battery out and reinsert it?
    Are you sure you're holding down all three buttons long enough?
    Did you even look for the correct model number? SGH-t999 - the firmware is http://samsung-updates.com/details/2...99UVUENC2.html
    eric0668's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks so much.
    It wouldn't do anything. I could have sworn I tried all combinations. In any case I went to Best Buy and surprisingly the young guy knew exactly what to do. By holding the vol+ and power and home it did go into whatever mode you call it. Recovery? Odin?
    To his surprise after clearing cache then factory reset the phone would not start again. At least he was able to do something I couldn't. He immed hooked it up to his computer and out the latest software on it and all was fine.
    GSDer likes this.
  6. #6
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Great! Thanks for the follow-up.
  1. SplashBlocks: Finally available on Google Play!
    By Michalis Prizas Froudarakis in forum Android Apps
    Last Post: 07-04-2014, 12:28 AM
  2. Voice Notifications lost after KitKat upgrade?
    By mattdettmer in forum Verizon LG G2
    Last Post: 04-30-2014, 09:17 PM
  3. Replies: 11
    Last Post: 04-23-2014, 08:24 PM
  4. Samsung Galaxy S4 freezing problems.
    By VGPOP in forum Verizon Samsung Galaxy S4
    Last Post: 04-23-2014, 04:28 PM
  5. Re-download Samsung App Store
    By PHunter22 in forum Samsung Galaxy S5
    Last Post: 04-23-2014, 10:38 AM
