1. Gregorich's Avatar
    Hi all,
    I setup my lock screen recently to see if I liked using it or not. It turns out, not so much. I tried to disable, but I'm unable to. I go Setting > My Device > Screen Lock > enter my password > and from there I should be able to select "none." However, it's there, but unable to be selected. It only says "Disabled by administrator, encryption policy, or credential storage."
    Does anyone know how I can get around this to disable the screen lock? Thanks!
    04-23-2014 09:56 PM
  2. GSDer's Avatar
    Sounds like your phone is running some corporate configuration that you can't disable. Is that the case?
    Is your phone encrypted?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    04-23-2014 11:02 PM
  3. Gregorich's Avatar
    My phone's not encrypted. I did have to setup an email account through work on my phone that's run through Outlook Office 365 and on the 'Mail' icon for my phone. Is it likely that's what causing this? Is there any way to disable that, or would the only way be do uninstall that email setup? Thanks!
    04-24-2014 10:42 AM
  4. GSDer's Avatar
    Yes
    You could talk to the IT guys, but I think you'll have to get them to remove that setup.
    04-24-2014 12:22 PM
  5. Gregorich's Avatar
    Great! Thanks for your help! I'll give them a shout and see if there's a way. It's probably unlikely since they'd likely say I'd be exposing company information without it, but worth a call. They're not paying for my phone, so it won't break my heart to not have the email on it. Thanks again!
    04-25-2014 01:03 AM
  1. Screen scratches really easily on the HTC One (M8)
    By matthew pollock1 in forum HTC One M8
    Last Post: 07-14-2014, 08:48 PM
  2. URGENT : APNs locked can't chose my option !
    By Aimar_69 in forum HTC One M7
    Last Post: 05-28-2014, 02:58 AM
  3. Replies: 11
    Last Post: 04-27-2014, 10:02 AM
  4. App to lock screen Android
    By TheMTtakeover in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-23-2014, 07:42 PM
  5. How to trouble-shoot app WAKE-LOCKS
    By pcguys in forum Android 4.4 KitKat
    Last Post: 04-23-2014, 06:14 PM
