Results 1 to 3 of 3
    ttvh06's Avatar
    Posts
    Global Posts
    2 Global Posts
    Default Samsung S3 Screen problem (unique)
    Screen is black in most cases. The screen works properly is in Download mode (Vol Down + Home + Power), very early during boot (see the "samsung" white logo then black afterward), in Kies odin mode (initiated by kies sw). When booting into recovery mode, the initial screen (samsung white logo with red text on top) is seen then black screen afterward. Problem suddenly started without warning nor with any known cause (wasn't dropped).
    Touch and phone is fully functional.
    Tried the following and the symptoms remain the same afteward.
    - odin3 flash to current samsung official rom (4.3 tmobile)
    - Kies to flash and initialize latest rom (I assume that's 4.3 tmo)
    - boot to recovery mode and did a blind cache wipe
    - boot to recovery mode and did a blind factory erase
    - odie3 flash again
    - even swapped with a good known working motherboard and the failure stays with the lcd screen assembly unit
    So this tell me that the problem is with the lcd screen assembly. But the really strange thing is the lcd definitely is working, just in some initial boot up state. If I have a schematic of the lcd assembly unit, i can do further digging, but as it, it's blind guess.
    Any tips, helps ?? Is there any diagnosis mode to test lcd?
  2. #2
    Default Re: Samsung S3 Screen problem (unique)
    Welcome to the forums!
    A puzzling issue, but it sounds like your display is the culprit, despite the fact that it works correctly when it first boots. Could be a heat-related issue.
    There are apps that you can use to put test patterns and color grids on the display and to check multi-touch, but those won't do you any good since the display shuts off.
    Here's a couple of sources for replacement screen assemblies:
    http://m.repairsuniverse.com/samsung...ent-white.html
    http://www.etradesupply.com/samsung-...-assembly.html
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  3. #3
    I have kinda exactly the same problem (sometimes the screen goes all black, sometimes it just glitch to black). I have done much of everything he did (except the blind wipes).
    Also, I'm in 4.4 but was working fine and I have like 2 months since that upgrade of the firm and like a week with this issue.
  1. Downloading Apps onto my Samsung Galaxy Ace
    By wizbit164 in forum Samsung Galaxy Ace
    Last Post: 05-07-2014, 01:12 PM
  2. Square Grid on screen?
    By Pinkman. in forum HTC One M8
    Last Post: 05-06-2014, 08:30 AM
  3. how to sync s3 calendar to my nexus 7
    By EVIL--- in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-05-2014, 10:36 PM
  4. Couple things I noticed coming from the S3...
    By throttlehappy in forum Samsung Galaxy S5
    Last Post: 05-01-2014, 07:19 PM
  5. Huawei ascend D1 Quad XL Problem
    By TRANE in forum Huawei Ascend D
    Last Post: 05-01-2014, 03:31 PM
