Hello,
I get this message whenever i plug the charger in and the phone is turned on, and when it's off i get an illustration of a yellow triangle and a thermometer with a high temp, and the phone vibrates.
Things i've ruled out or tried:
1. The battery has a high temp; nope. The battery is room temp and this still happens.
2. Battery faulty. Tried a different battery, still occurs. Tried a different S3 with the same battery, doesn't occur.
3. Charger faulty. Have tried different Samsung and non-samsung chargers. Have tried a different S3 with the same charger.
4. USB port needs cleaning. Brushed port inside and out with toothbrush soaked in 100% isyprop alcohol. Picked out blobs of dust/lint. Nice clean port, but problem still exists.
5. Pins not connecting. Bent usb port connector up very slightly, no change. Also tried wiggling cable.
6. Did Factory Reset.
7. Wiped Cache.
8. Took battery out, plugged charger in, then inserted battery.
Things to note: The phone was hanging on the startup logo (this is how i received the phone), and i had to enter download mode and reinstall factory firmware through KEIS to get it working again.
Not sure where to go from here. Can only be used by charging battery in another device, and then putting in phone. Any advice?
7. Wiped Cache.
