X X-Nemesis Well-known member Sep 4, 2012 99 0 0 Visit site May 5, 2014 #1 My GS3 has suddenly become unable to connect to my Asus RT-N66U Router at home. It just says "Obtaining an IP Address". Any advice on how to fix this?
dbareis Well-known member Jan 15, 2010 324 10 0 Visit site May 5, 2014 #2 Remove the current WIFI definition and recreate Check Router for any MAC addresss filtering
X X-Nemesis Well-known member Sep 4, 2012 99 0 0 Visit site May 5, 2014 #3 Thanks, I'll give that a try
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 200 63 Visit site May 5, 2014 #4 Also try to restart the router dpham00, Android Central Moderator Sent from my Verizon Samsung Galaxy Note 3
L Lime soda New member Sep 7, 2014 4 0 0 Visit site Sep 12, 2014 #5 Could you explain removing WiFi definition a bit better I don't quite understand sorry. Posted via the Android Central App
AxlMyk Well-known member Sep 12, 2012 1,217 0 0 Visit site Sep 13, 2014 #6 Settings, wifi, long press your wifi, forget it. Bottom of list, + add wifi network AC App on SGS3
