1. Beatnink's Avatar
    On my S3/Android 4.3 device I have had the problem for a month or so now that the sound volume drops when the equalizer kicks in, e.g. in Google Play Music or the Android Music Player. It happens with both the Equalizer or MusicFX apps. The moment I turn off the equalizer, the volume goes to the normal level. I also get a loud crackle every now and then when stopping the music.
    Anyone else experiencing this? Any solutions?
    05-07-2014 03:38 PM
  2. BadgerVadge907's Avatar
    too much bass frequencies below 60hz did do that when i had the gs3. try to find an eq app that also has a preamp or gain future and turn off compression. also is it doing it with headphones? or speaker?
    05-07-2014 07:10 PM
  3. wms3's Avatar
    Instead of the stock Android player, download poweramp. It is an awesome player that includes an excellent equalizer. You can save as many custom equalizing curves as you would like. I'm using it even as I type this message.
    Posted via my Samsung Galaxy iPhone killer
    05-08-2014 04:06 PM
  1. What do YOU search for when looking for a game?
    By Qperience in forum The Gamer's Lounge
    Last Post: 05-16-2016, 12:13 AM
  2. Does 4G LTE Symbol is shown in the device? Samsung Galaxy S5
    By pepejjla in forum Samsung Galaxy S5
    Last Post: 01-19-2015, 07:36 PM
  3. Does The Phone Keep Searching For 4G Signal Even In WiFi?
    By PsychDoc in forum Samsung Galaxy S5
    Last Post: 05-07-2014, 04:28 PM
  4. Stock Calendar: No graphics or text in month view
    By Jaycita Byrne in forum Samsung Galaxy S4
    Last Post: 05-07-2014, 02:46 PM
  5. What is ok to disable in bloatware on the M8?
    By F8ker8 in forum HTC One M8
    Last Post: 05-07-2014, 01:26 PM
