Disable auto-lock in driving mode
Lanny Lin
5
Is there a way to automatically disable auto-lock in driving mode, so I don't have to try to unlock the phone with finger gesture patterns while driving? It seems logical to have such an option. I do want auto-lock when I am not driving though.
Thanks a bunch!
Welcome to the forums!
If you're using a Bluetooth connection you could try something like Delayed Lock: https://forums.androidcentral.com/e...=de.j4velin.delayedlock2.trial&token=SvudV-0B which allows you to forgo the lock screen when connected to a trusted device. There's similar apps, or things like Llama: https://forums.androidcentral.com/e...pps/details?id=com.kebab.Llama&token=cf9R0nO7 (and too many others to list) that allow you to set conditions for actions.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
liquidsnake757
