Results 1 to 4 of 4
    Default sprint galaxy s3 will not turn on
    i have a rooted sph-l710 sprint gs3. i was loading the stock rom and unrooting it which ive done many times before with the same file using the same technique on the same phone. i loaded it via recovery mode zip file and it loaded and succeeded with no problems, then ticked reboot phone now and it shut down and wouldn't come back on. i do know what im doing because i been messing with phones for awhile now i.e rooting, custom roms, ect. i went to restart it and it wont turn on at all. i tried charging a spare battery in a wall spare battery charger and it still wont turn on. when i plug the phone in to charge it the normal way through the charging port, the led dont even light up. its dead like there's no battery in it. does anyone know what i can do to fix this aside from taking it in? Any help is appreciated. thank you.
  2. #2
    Default Re: sprint galaxy s3 will not turn on
    Quote Originally Posted by denschwindt View Post
    Take the battery out for 10 minutes, then put it back and turn on
    can you get into recovery or download menu
    if not buy USb JIG it will force phone to enter recovery menu.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,756 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Also, try seeing if the battery is bulged. Take it out, set it on a flat surface and spin it. If it does spin easily, it needs to be replaced.
  4. #4
    You could see if you can find a debrick image for it over on XDA.
    Or use a JTAG service (ex. http://mobiletechvideos.mybigcommerc...-brick-repair/).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  1. New S5 Galaxy Display issue
    By Cybageek in forum Samsung Galaxy S5
    Last Post: 05-10-2014, 06:38 PM
  2. Emoji's on S4
    By silverpetals in forum General Help and How To
    Last Post: 05-10-2014, 07:42 AM
