Page 1 of 2 12 LastLast
Results 1 to 25 of 39
    Default My phone wont turn on
    Hi,Today evening i got a normal pop up on my Samsung phone for software update I choose the option to update and then i had a message on the screen that your phone will Re-boot it did install the software last i saw was 42% after reboot it only shows Samsung written on the phone, i tried to remove the battery restart my phone but still it shows me the same. Can you please help me to on my phone. Waiting for your earliest reply.
  2. #2
    Default Re: My phone wont turn on
    Quote Originally Posted by Diksha Peswani View Post
    go to recovery clear cache
    then turn on your phone and wait for the update to complete
    wait for 5-10 minutes for update to compete . if your are still stuck
    clear cache and data form recovery
    clearing data will remove apps and games from your phone
    Hi,
    Where do i go to recovery clear cache ?
  4. #4
    Hi,
    power off the device
    press Volume Up + Home + Power ON buttons at the same time and hold them pressed
    most of Glaxy devices boots twice to enter recovery mode, so just hold keys pressed and wait
    release buttons when CWM announce itself
    use Volume Up/Down and Home button to pick menu entries
    Ready to help you
    Diksha Peswani likes this.
    Power off the device... that means i shall remove the battery and insert again then follow the steps.
    Because now all i can see is samsung on my phone and when i power off.. it starts again with Samsung display on the phone in seconds.
    Ok i have done that it gives me a option of
    reboot system now
    apply update from ADB
    Apply update from external storage
    wide data/factory reset
    wipe cache partition
    apply update from cache
    Can you tell me which option i should choose. I do not want to loose my data.
  7. #7
    reboot system now
    turn on your phone again
    if the update is not show up or stuck then you need to wipe data/factory rest
    wiping data will remove all the apps and games
  8. Thread Author  Thread Author    #8
    Hi,
    I choose wipe data/ factory reset and it shows No no no no and one yes - delete all user data. Should i choose yes ?
  9. #9
    Hi,
    have you checked the update, wipe cache and restart. check whether the update is still going or not . if the update is still stuck then you need to go to recovery and clear data
    if you press yes all your data will be lost and your phone will up
  10. Thread Author  Thread Author    #10
    When i choose wipe cache partition - it said Wiping cache... fomatting / cache... cache wipe complete. And thats it.
    Then I choose wipe data/ factory reset and it shows No no no no and one yes - delete all user data. Should i choose yes ?
  11. #11
    pressing yes will delete all the data in your phone that you have download from play store, not the stock apps
    your phone will boot up with stock apps
  12. Thread Author  Thread Author    #12
    I Selected no.
    When i choose wipe cache partition - it said Wiping cache... fomatting / cache... cache wipe complete. And thats it. What do i do next ?
  13. #13
    I Selected no.
    Restart your phone
    Is your phone booting up? Check that first
    If not then you needed to wipe data and press yes.
    It will delete the downloaded apps only
    Ready to help you
  14. Thread Author  Thread Author    #14
    I restart my phone again. But nothing i can still see Samsung on my display. What do i do next ? Which option do i choose ?
  15. #15
    So you need to wipe data / factory reset from recovery, then restart
    If you are still stuck then reflash with odin
    Download the latest firmware from sammobile and flash it
    Ready to help you
  16. Thread Author  Thread Author    #16
    By wipe/data factory will i loose all my data ? Pictures ?
  17. #17
    Just apps and games you have downloaded from playstore.
    Picture,music will not be deleted
    Ready to help you
  18. Thread Author  Thread Author    #18
    Hi,
    I did select wipe/data factory reset and then selected yes. Again Restarted the phone, but still the same i can see the SAMSUNG on my display. But this time i could hear the Samsung Welcome tone as before i dint hear it. Now what do i do next ? ):
    Regards,
  19. #19
    Hi,
    Regards,
    how long did you waited at the samsung logo.usually it will took 1 to 2 minutes to boot up after cleaning data for the first time
  20. Thread Author  Thread Author    #20
    It is almost been 20 minutes now
  21. #21
    sorry for the delay you need to reflash your firmware vie odin . download the latest firmware from sammobile then reflash it with odin. flashing with odin is easy
  22. Thread Author  Thread Author    #22
    From my pc i should download ?
  23. #23
    yes you need to download it from pc, it will be zip file you need to extract it.i will pm you the tutorial for flashing.
    Ready to help you
  24. Thread Author  Thread Author    #24
    It is a free software ?
    mobilecrackers likes this.
  25. #25
    everything is absolutely free ,you need to download it. if you are first time flashing just google it. it's simple but difficult for newbies.just 2-3 minutes your phone will be flashed.
    Ready to help you
    cranky_bot likes this.
  1. Galaxy S5: no "media audio" on Prius bluetooth
    By Erol Fox in forum Samsung Galaxy S5
    Last Post: 11-11-2014, 08:51 PM
  2. Disable S-Voice on home button press?
    By tannerrblake in forum Samsung Galaxy Note 3
    Last Post: 08-24-2014, 09:42 AM
  3. I need the OnePlus One. Please invite me
    By KLIMAXX in forum OnePlus One
    Last Post: 05-19-2014, 10:12 PM
  4. M8 Worst phone 637 data used
    By waz ahmer in forum HTC One M8
    Last Post: 05-13-2014, 03:43 PM
  5. Why does my phone do this?
    By Lucy Davies in forum Samsung Galaxy S4
    Last Post: 05-13-2014, 10:13 AM
