1. amoledsucks's Avatar
    I hav a Samsung galaxy s3 whose battery drains very fast...I hav turned off sync, gps, smart stay, etc...I get just 5-6 hrs of backup under normal usage with wifi kept on...can one tell me is der ny problem wid my fone
    05-12-2014 04:13 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It would help if you posted some screenshots of your battery stats--specifically, the graph, the breakdown of percent battery use, the screen-on time, and the time without cell signal (part of Cell Standby).
    In the meantime, review this guide: [Guide] Battery Saving Tips
    05-12-2014 03:04 PM
  3. cranky_bot's Avatar
    I had the same problem, now i downloaded an app called Easy Battery Saver or something like that and it helps a bit, i still bring spare battery wherever i go, in case..
    05-13-2014 01:59 AM
  4. mobilecrackers's Avatar
    Go to recovery and clear cache
    Press THANK YOU and LIKE button if you gets the answer
    05-13-2014 02:05 AM
  5. porshacat's Avatar
    How do you 'go to recovery' ?
    01-30-2015 07:36 AM
  1. Is there a way to get my alarm time on the lock screen?
    By woahohkelsey in forum Samsung Galaxy S5
    Last Post: 07-27-2015, 02:08 AM
  2. Help restoring Apps after switching from S2 to S3
    By Rob James3532 in forum General Help and How To
    Last Post: 05-13-2014, 10:08 AM
  3. I need help about my Android!
    By DJShawnz in forum General Help and How To
    Last Post: 05-13-2014, 03:14 AM
  4. Samsung Galaxy Y(oung) GT-S6310N - help??
    By Vickie_D_80 in forum General Help and How To
    Last Post: 05-12-2014, 03:06 PM
  5. 17 day battery life
    By Lancer033 in forum Google / Samsung Galaxy Nexus
    Last Post: 05-12-2014, 08:57 AM
