Results 1 to 4 of 4
    Katie Rose2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung s3: why do I have to keep reconnecting to the network?
    Work have just installed Maas360 on my phone. Now, when I try to connect to the internet via 3G, it looks like it has connectivity, but doesn't send or receive data. Instead, I have to go into my settings, and select Vodafone in network operators and it connects. However, every few hours, the problem recurs. Does anyone know why this is happening and how to fix it, please? Thanks in advance...
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung s3: why do I have to keep reconnecting to the network?
    Welcome to the forums!
    Sounds like you need to contact 'work', since they foisted this Maas software on you. I'm guessing that you didn't have this problem before they did their magic?
    You shouldn't even have to select the network operator - there should only be one.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, I agree, I've asked them to look into it, but I wondered whether there might be a fix or work around... Any further advice out there??? Thanks
  4. #4
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you go to Settings -> Connections (if using the Tab view) -> More networks -> Mobile networks -> Access Point Names, is there more than one listed?
    Are there other selections under Network operators?
  1. What comes in the box when you choose the Rx frames?
    By WwonderLlama in forum Google Glass
    Last Post: 09-30-2014, 07:05 PM
  2. Replies: 6
    Last Post: 07-11-2014, 11:30 AM
  3. [New Release] Tribeat - The stylish, endless platformer
    By SleepMakePlay in forum Android Games
    Last Post: 07-08-2014, 06:42 AM
  4. What woul dyou do
    By bsannes in forum Verizon
    Last Post: 05-14-2014, 06:48 PM
  5. Asus MeMo Pad HD7 apps to sd card
    By alb28 in forum General Help and How To
    Last Post: 05-14-2014, 02:54 PM
