1. jam24u's Avatar
    I have been downloading movies from movie streaming websites like VEEHD. They allow downloading of movies, but they are designated by a seven digit number, so when the movie is retained in the "Video" app.... they are labeled by number instead of the movie's name... which makes it hard to identify the film.
    If there is a way to change these movies names and keep them in that original video app ( the one with the purple background icon with a white diamond outline within it and with "video" written below the icon... would be very helpful. I really like this app because it allows auto playing of the videos one after the other. I usually sleep to the various videos, and is why I wish to work within that app.
    If I do need to download some file management application, I would appreciate a recommendation.
    In addition... if you have already guessed... I am a complete novice in tech talk... I see words like 'Rom' and have no idea what that is.
    Thank you for your advice and recommendations.
    05-15-2014 01:42 PM
  2. GSDer's Avatar
    If I'm reading you right you're talking about the stock Video app. On my phone all of the videos shown in that app use the actual filename of the video file, so all you need to do is use the File Manager of your choice (My Files would work fine) and rename the files to whatever you please.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    05-16-2014 09:27 PM
  3. AxlMyk's Avatar
    In other words, find the file, long press on it, rename.
    AC App on SGS3
    05-17-2014 08:38 AM
  1. Water damaged s4 will not come on or charge
    By Essence Jackson in forum Samsung Galaxy S4
    Last Post: 05-15-2014, 04:55 PM
  2. Help: "Device management is r..." in notification
    By justlaxin13 in forum HTC One M8
    Last Post: 05-15-2014, 03:53 PM
  3. Please help. Serious problem with my M8!
    By auctioneero in forum HTC One M8
    Last Post: 05-15-2014, 03:43 PM
