Results 1 to 4 of 4
    lggarciar91's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S3 battery won't charge more than 30%
    Hello, I'm new to the forums, and I appreciate your help on this matter.
    I've owened a Galaxy S3 for 9 months. I rarely turn it off, it's on 24/7 and charge it always when the battery has emptied in full.
    Last week I did a couple of half charges and then it started to become slow in the functions compared to how good it has always worked.
    Yesterday the battery emptied so I charged it all night and in the morning it showed to have 28%. I checked the charger and the connections and they were all good, so I charged it for another 2 hours. Nothing, it won't go pass 30%. Took it off and used it to check facebook, it ran empty in 10 minutes. Charged it again and it won't pass the 30%.
    I'm guessing the battery has to be replaced, but I'd really appreciate your help on this, just to be sure.
    Thanks!
    Luis
  2. #2
    AxlMyk's Avatar
    Posts
    Global Posts
    1,244 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S3 battery won't charge more than 30%
    You should get in the habit of charging it every night. Draining the battery isn't necessarily the best thing to do.
    Try a Ravpower 2250 mah battery. I have one and really like it.
    AC App on SGS3
    lggarciar91 likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks AxlMyk!!
  4. #4
    rich6440's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Your usb phone connector is broken .Usually the 5 volt pin cracks loose.You need to have it resoldered.
  1. One M8 - Stuck in recovery, Screen won't turn on. Please help!
    By andrewpr52 in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 07-20-2015, 11:03 AM
  2. Battery since May OTA
    By T-Rob in forum Motorola Droid MAXX
    Last Post: 06-17-2014, 12:07 AM
  3. Telescope for GS3 with review and pictures
    By AxlMyk in forum Verizon Galaxy S3 Accessories
    Last Post: 05-29-2014, 12:26 PM
  4. Replies: 0
    Last Post: 05-17-2014, 04:48 PM
  5. Unlocking Galaxy Tab 3 10.1
    By Santiago Pedraza in forum Samsung Galaxy Tab 3 Rooting, ROMs, & Hacks
    Last Post: 05-17-2014, 01:21 PM
