1. 100watt's Avatar
    I had the S3 for about two months now and within 5 minutes of taking the charger off the battery goes down to 97%. I work a 12 hour shift and use it during my breaks only so it gets about 45 minutes of use out of 12 hours and it's around 65% battery life. Why is the battery dropping so soon after unplugging when I'm not even doing anything?
    05-18-2014 09:20 PM
  2. AxlMyk's Avatar
    Take a snapshot of the battery display in settings, and post it.
    Sent from my SCH-I535 using Tapatalk
    05-18-2014 09:25 PM
  3. 100watt's Avatar
    Here's a screenshot.
    05-18-2014 09:58 PM
  4. AxlMyk's Avatar
    My screen usually reads 20-25%. Are you using timeout to turn the screen off, or doing it manually.
    I always press the power button when not using the phone to turn the screen off.
    05-18-2014 10:22 PM
  5. 100watt's Avatar
    I have it set on one minute timeout.
    05-18-2014 10:32 PM
  6. GSDer's Avatar
    You really need to include three screenshots - the Battery view (which you included), the Screen On details (press the Screen item) and the History details (press the graph at the top of the main view).
    It's pretty normal for the battery to drop a couple of percent right after disconnecting the charger - the battery is seldom actually full, but starts to discharge once it reaches 100%, and then the trickle charger starts to bump it back up, so depending on where it was at when you unplugged it you'll see some variation.
    And frankly I don't see anything wrong with your battery data - you got about 24 hours and still have 46% remaining. The rest of the screenshots will help to paint a clearer picture.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    05-19-2014 02:59 AM
  1. Galaxy Y battery discharging very fast
    By whizclips in forum General Help and How To
    Last Post: 04-15-2015, 12:32 PM
  2. Replies: 6
    Last Post: 05-24-2014, 05:24 PM
  3. S4 Battery Drain Help. I'm a newbie.
    By lakcore in forum Samsung Galaxy S4
    Last Post: 05-20-2014, 02:20 AM
  4. Discharging While Plugged In/Constant Battery Loss
    By romanguy13 in forum T-Mobile Galaxy S III
    Last Post: 05-19-2014, 03:50 PM
  5. How's this battery usage look
    By perithimus in forum Samsung Galaxy S5
    Last Post: 05-18-2014, 11:41 AM
