1. marcos cruz asap's Avatar
    i had this phone for 2 month now everytime i charge it when its on or off its really so i take off my battery pack but when i put it back in the battery life goes up to like 72% but when i charge it from there its the same thing so i take off the battery pack after it turns on its goes down to 8% this just keeps going on ...
    plz help asap
    05-19-2014 01:03 AM
  2. Kelly Burby's Avatar
    plz help asap
    Well, seriously telling I don't seem to get what you are talking about ? Your words are just too much confusing I can't seem to draw what problem you are facing.
    05-19-2014 01:40 AM
  3. GSDer's Avatar
    I'm also a bit confused. Are you using the charger that came with the phone (the wall transformer and separate cable)?
    Do you have an external battery charger?
    If you use the wall charger and turn the phone completely off you should see a charging graphic showing the battery level and charging activity, and it should only take about two hours to fully charge the phone.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    05-19-2014 01:46 AM
  1. s3 mini - how to set default storage to sd card?
    By jrmama42 in forum Samsung Galaxy S3 Mini
    Last Post: 07-23-2014, 12:58 PM
  2. USB Charger/Heating Problem
    By coldtone in forum Google Nexus 5
    Last Post: 06-10-2014, 08:37 AM
  3. Galaxy S3 No Longer Booting after Failed Factory Restore
    By Sabeek Pradhan in forum AT&T Galaxy S III
    Last Post: 05-24-2014, 06:59 PM
  4. Battery Life
    By 100watt in forum Samsung Galaxy S3
    Last Post: 05-19-2014, 01:59 AM
  5. Replies: 2
    Last Post: 05-18-2014, 10:19 PM
