1. Rescueadog's Avatar
    Excuse my ignorance but all the really comprehensive advice on these threads is baffling me!
    What I seem to have gathered is that my phone needs to have software reloaded. In order to hopefully preserve files, I could try this via Odin rather than Kies, which although seems the better option, would wipe my phone.
    I've pressed the Volume+Power+Home buttons simultaneously, stopped immediately Samsung logo came on, pressed the Volume+Power+Home buttons simultaneously again and got to a page that said something about OS and pressing Volume Down would cancel, Volume Up would take me to continue. I did Volume Up as Volume Down only took me back to the frozen log page! So I'm now at Downloading Do not turn off target!! But I don't know how to proceed.
    Not sure I got to this stage via the Recovery or Downloading screens, as the info that other people have described seeing on their phone didn't show up on mine. And I didn't get the option to clear Cache (whatever that is, can't see it in the glossary!:-)) But here I am at the same place.
    Your advice, in simple as possible language, would be of great value to me and my squidgy mind, thanks in advance
    05-20-2014 02:38 PM
  2. GSDer's Avatar
    Welcome to the forums!
    If you reload the same version of firmware using Odin that your phone previously had on it that'll give you the best chance of getting your data back, but there's no guarantees.
    If you choose to use Odin you'll have to download the firmware yourself - look here - select your device in the drop-down list in the upper left corner, then find the version of firmware that you had (hopefully the latest).
    You can find Odin online (just Google it - look for v3.07; your best bet is to select a source from XDA) and there are instructions on how to use it in the rooting sub-forums or online (most of them have screenshots showing everything step by step so it's pointless to try to reproduce that here).
    If you're not sure which firmware to use please provide your model number/carrier/region (if an International user).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    05-21-2014 01:01 AM
  3. Rescueadog's Avatar
    Thank you!
    How do I know which version it previously had?
    And what does mirror mean, and how do I know whether to pick TerraFile or RapidGator?
    Ah, think you answer this at the end - as in I'm not sure. Model number is GT-I9300. I'm on Orange (EE) in England, which I couldn't see on the list.
    Cheers!
    05-21-2014 02:38 PM
  4. GSDer's Avatar
    http://samsung-updates.com/details/2...00XXUGML2.html is the firmware you need. It doesn't matter which mirror you use - Terafile is fine.
    05-23-2014 01:52 AM
  5. Rescueadog's Avatar
    Thanks you GSDer. I've used your link and ended up downloading iMesh, a music sharing site.
    I'm really not getting this, sorry! I thought this would be the link to the firmware and I now download it from this site, but I can't see how. There doesn't seem to be an option to find phone or any firmware.
    Do I now go to Odin too to find my firmware? I'm totally confused. I'm trying to research but I'm getting more bogged down by it all. Again your help is appreciated:-)
    05-24-2014 09:23 AM
  6. GSDer's Avatar
    It is the link to the firmware. See the screenshot belowJust to the right of the filename you need to select the 'Regular' Text. That'll take you to the next screen shown below after a ten second countdownAgain to the right of the filename you'll have to enter the words that you see and then select 'Create Download Link' and then use that to download the firmware.
    Basically, do not select any of the other crap on the web page - it's all there to generate ad-based revenue.
    05-24-2014 10:20 AM
  1. So is it coming to Verizon or not???
    By godsidekurt in forum Sony Xperia Z2
    Last Post: 06-16-2014, 06:18 PM
  2. Replies: 2
    Last Post: 05-30-2014, 05:21 PM
  3. How to update my HTC rezound to jelley bean 4.2
    By Kenneth Acquah in forum Verizon Droid Incredible 4G
    Last Post: 05-20-2014, 02:03 PM
  4. Just found_FREE Lock Screen App_Pays you or GIVES TO CHARITY
    By Johnny Ricardo in forum General News & Discussion
    Last Post: 05-20-2014, 01:43 PM
  5. Samsung S5 intermittant data lose/slow download
    By richster1 in forum Samsung Galaxy S5
    Last Post: 05-20-2014, 01:40 PM
