1. safariJack's Avatar
    Hello,
    I just switched from an old android to a galaxy s3 and group messaging doesn't appear to be working the way that it should. I do have the group messaging setting checked. I received a group message and everything looked fine. One person replied, but it came in a separate individual thread. I replied to the group message thread, and it said it went to everybody. The person who started the message then replied, but it came in a separate thread. I didn't receive the other replies at all.
    Why would group messaging only half-work like this? The message starter has an iPhone and the first message worked. One thing of note is that each time that I open the group message thread a pop up says "converting to multimedia message for group messaging..." Here are my specs:
    Galaxy S3
    Android 4.4.2
    Sprint/Virgin Mobile
    Messaging App (Stock)
    Thank you for any help!
    short: Group message came to me and my reply went back ok. Two replies from others came as separate threads, others didn't come at all.
    05-27-2014 02:45 PM
  2. GSDer's Avatar
    Welcome to the forums!
    How many of those in the thread are on iPhones?
    I've found that the success of group messaging depends as much on the others in the group as on me; half the time other people aren't using the 'group' features. But that's just been my experience - YMMV.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    05-27-2014 05:50 PM
  3. safariJack's Avatar
    Thank you GSDer!
    Most if not all in the thread were on iPhones.
    05-27-2014 06:16 PM
  4. GSDer's Avatar
    Bummer. All I keep hearing about messaging issues where iPhones are concerned involves turning off iMessage (or something like that). Perhaps if you get on the iMore site something might shed some light on the situation. Sorry to be of no use.
    05-27-2014 11:52 PM
  1. Default Messaging app always shows a '1' unread count
    By ManiacalMF in forum Motorola Droid MAXX
    Last Post: 03-04-2017, 02:37 PM
  2. Replies: 7
    Last Post: 07-16-2014, 05:19 PM
  3. Battery problems causing Wifi settings to disappear!?
    By Scarymole in forum Samsung Galaxy S3 Mini
    Last Post: 05-27-2014, 11:35 PM
  4. Downloading problem
    By Mst99 in forum Samsung Galaxy S5
    Last Post: 05-27-2014, 10:26 PM
