Results 1 to 4 of 4
    Exclamation Galaxy S3 Won't Turn on and Yellow LED Flashing Light
    I need some help, my Galaxy S3 is not turning on at all. The LED light is blinking yellow-orange and I'm confused. It is charging, and it still won't turn on.
  2. #2
    Default Re: Galaxy S3 Won't Turn on and Yellow LED Flashing Light
    I don't think I've ever seen the LED flash yellow. Not sure what that means. Have you tried to boot into recovery or download mode?
    Well, I'm not sure...I don't know if I can since I am not able to turn on my phone.
  4. #4
    Welcome to the forums!
    Have you tried removing the battery for a few minutes and then reinserting it?
    When the phone is connected to the charger do you see a battery graphic showing the battery level and charging activity?
    Here's an overview of Recovery mode and Download mode:
    - you use Recovery mode to clear the system cache and to Factory Reset
    - you use Download (aka Odin) mode (showing the Android guy) to load/reload firmware
    - the key sequences to enter both modes are very similar, and they are timing dependent so it may take a few tries to get it working
    -- Recovery = Volume Up + Home + Power
    -- Download = Volume Down + Home + Power
    - for either, you start with the phone completely off
    - press and hold the required keys simultaneously, and release them all when you see the swirling logo (not the static white text)
    Try Recovery mode first (use the Volume rockers to navigate; use the Power button to select) and if it boots into this mode just clear the cache and then restart. If the phone doesn't boot normally then try Download mode - if that works let us know and we'll go on to the next step.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  1. Galaxy S5 Wireless charger bump case
    By Northern.dj in forum Samsung Galaxy S5 Accessories
    Last Post: 12-30-2014, 07:37 PM
  2. Galaxy S5 Hart rate Monitor
    Last Post: 06-03-2014, 06:27 PM
  3. Thoughts on Tmobile switch
    By nrvna76 in forum T-Mobile
    Last Post: 06-01-2014, 11:08 AM
  4. New owner of Verizon Samsung Galaxy Note 2. Question about display
    By JewDaddy in forum Verizon Galaxy Note 2
    Last Post: 05-31-2014, 03:07 AM
  5. What's a cool looking and deadly weapon
    By KLIMAXX in forum The Android Central Lounge
    Last Post: 05-30-2014, 10:21 PM
