Results 1 to 7 of 7
    Default Screen Issues- Galaxy s3. HELP!
    I have no idea what is going on with my screen. I took my phone to best buy because they installed 4.3 on my phone the day before, but they said everything looks normal on my screen....what?! The screen flashes purple when I unlock it and now the screen is sort of filling up with a gray screen and it pixelates everything on my screen. I will attach of picture of it in action of filling up. I just want to know if others are having this issue and if it's worth it to try a factory reset. The picture shows the gray at the bottom of the screen which eventually just consumes my entire screen.
    Attached Thumbnails Attached Thumbnails Screen Issues- Galaxy s3. HELP!-photo-6-2-14-2.24-pm.jpg
  2. #2
    Default Re: Screen Issues- Galaxy s3. HELP!
    Welcome to the forums!
    It sounds like the folks at Best Buy made an error or got unlucky and had a bad firmware load. If you show them what's happening they should be able to re-flash the firmware, clear the system cache and perform a Factory Reset - after that everything should be back to normal.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    I took the phone back the next day and the man plugged it into the computer and checked my settings and told me there's nothing wrong with my screen. He also told me he had no idea why my screen was flashing purple. Frustrating. Do you think I should bring it to another Best Buy and see if they can re-flash the firmware for me? I did the system cache today I think by pressing home, power and volume up at start up.
    Thanks for your help! I appreciate it.
  4. #4
    You'd think it would be pretty obvious - before they flashed the firmware your screen was fine; after they flashed the firmware your screen is flashing purple. It's not rocket science.
    Yes, you can try a different Best Buy or you can try using the Kies software on your computer to reload the firmware. Let us know how you'd like to proceed.
  5. #5
    So much for BestBuy.
    Boot the phone into recovery mode and do a factory reset.
    AC App on SGS3
    Quote Originally Posted by GSDer View Post
    You would think they would realize that they did something wrong! I will take it to another store, because for some reason Kies is gone on my phone and I cannot find out how to get that back either. Just my luck. August cannot come soon enough for me to upgrade to an S5!
  7. #7
    Quote Originally Posted by Brie Liberatore View Post
    Kies is software that you install on your computer, not on your phone. If you haven't used it before just do a Google search - look for v3.
    It's a great tool for backing up the contents of your phone, apart from its use to reload the firmware.
  1. Vibrate/Ringer issues after Kit Kat update
    By me10lee83 in forum Droid RAZR MAXX HD
    Last Post: 06-11-2014, 05:37 PM
  2. Rings then speaks callers name issue, after Kit Kat update
    Last Post: 06-10-2014, 05:43 PM
  3. Share your Samsung Galaxy S4 screenshots!
    By rabijlassi in forum Samsung Galaxy S4
    Last Post: 06-02-2014, 05:22 PM
  4. galaxy s5 battery drain
    By Ian Bennett in forum Samsung Galaxy S5
    Last Post: 06-02-2014, 02:46 PM
  5. Replies: 0
    Last Post: 06-02-2014, 01:37 PM
