1. joeyv8082's Avatar
    Sorry in advance if this was posted elsewhere. I couldn't find any threads regarding my issue.
    I have a Sprint gs3 on android 4.4.2, and just within in the last day or so if I make a call then promted to press a number for an option, the touch tone won't go through.
    For example if I dial Sprint and get press 1 if you are calling about (my number) and I press 1, nothing happens. I dial other numbers and nothing. Also I've tried other calls and the same thing so it's not Sprint's system.
    Customer care did a master reset and I tried some 3rd party dialers also and nothing.
    Thanks in advance for any suggestions.
    06-05-2014 07:13 AM
  2. Golfdriver97's Avatar
    I would try rebooting into recovery and clearing the system cache. Here is how: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    06-05-2014 08:17 AM
  3. joeyv8082's Avatar
    tried wiping the cache partition didn't work.
    06-05-2014 09:09 PM
  4. Golfdriver97's Avatar
    OK. The only other thing I can suggest is a reset. Back everything up, and then in settings>back up and reset, click on factory restore.
    From a Carbon M8 and AC Forums app
    06-05-2014 11:19 PM
  5. joeyv8082's Avatar
    ***update***
    thanks for the replies to my question. As it turns out after trying everything under the sun, i went to the sprint store with my tail between my legs to find out if i could get a loaner phone while i send mine to samsung for repair....turns out it's a spring network issue in the cleveland market and not a phone issue at all....
    so ill fasten my seatbelt and sit back and enjoy the ride...
    thanks again
    06-07-2014 08:33 AM
  6. _YoKolorMeBadd's Avatar
    My Verizon S3 does that sometimes also. At times I can't make calls or use data, its very annoying.
    Sent from my SCH-I535 using Tapatalk
    06-09-2014 09:02 AM
  7. ggalmin's Avatar
    Would anyone have any insight to as why when i use the handy search feature in the dialer to find a local restaurants number, that when i go to hit talk, it pre-pends a a stupid + in front of every number i try to dial that way (and a fast busy). I am in the states on a Nexus 5 with Sprint. I have to either edit the number before a re-dial attempt or just wright it down on paper... kinda defeating its handy intention
    06-19-2014 12:25 PM
  8. GSDer's Avatar
    I must be totally clueless - I don't see ANY search feature in the DialerAre you talking about the Contacts Tab? Can you post a screenshot of what you're referring to?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    06-19-2014 03:11 PM
  1. internal storage problems with tablet
    By Joey Deke in forum General Help and How To
    Last Post: 06-06-2014, 10:17 AM
  2. problem viewing pictures
    By Jaramie3 in forum Google Nexus 5
    Last Post: 06-05-2014, 07:51 AM
  3. Problem copying data from SD card, to new SD card
    By rattandmouse in forum HTC One M8
    Last Post: 06-04-2014, 04:50 PM
  4. problems with native email app since upgrading to OS 4.4.2
    By klhprice in forum Samsung Galaxy S4
    Last Post: 06-04-2014, 04:27 PM
  5. Urgent Help Needed: Problem when flashing stock firmware.
    By Casey_Grim85 in forum Samsung Galaxy S4
    Last Post: 06-04-2014, 02:45 AM
