1. Timmyethy123's Avatar
    So,
    I was texting with a friend of my and suddenly the phone turns off. This happens more than 1 time a month so I wasn't to worried.
    But after trying to start my phone again (Just a normal start) it stayed at the splash screen. It plays a part of the 'intro' sound but does not continue any startup.
    What I already tried:
    Rebooted the phone countless times
    Factory reseted the phone with the download thingy startup (Volume Up + Home + Power(Tried that about 5 times))
    I'm completely clueless why it does this and I hope someone can help me.
    In forward, Thanks
    P.S.: There might be some grammar or spelling mistakes but don't blame me. I'm from The Netherlands. Thanks
    06-10-2014 10:22 AM
  2. GSDer's Avatar
    Welcome to the forums!
    I would never accuse someone who probably reads/writes/speaks more languages than I have pairs of shoes of bad spelling/grammar!
    This is unfortunately an all too common problem. Your only recourse is to reload the firmware, which you can do using either the Kies software on your computer or using a tool called Odin.
    If you haven't already used Kies you can find it online - just Google it; if your phone had the 4.3 firmware update then you'll need Kies v3; if it had 4.1.2 or earlier firmware then you'll need Kies v2.6. Kies will handle determining the correct firmware for your phone, downloading it from the Internet and installing it on the phone.
    If you decide to use Odin (just Google it - look for v3.07; pick a source on XDA) you'll have to manually download the firmware, which you can find here - select your device in the drop-down list in the upper left corner, then mouse-over the region codes to find your country/carrier. You can find instructions on how to use Odin here
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    06-10-2014 11:20 AM
  3. Timmyethy123's Avatar
    Okay I will try the Kies method first once I get home. Thanks GSDer!
    06-10-2014 11:47 AM
  1. Samsung GT-P3100 restarts automatically
    By Ritanjan Belgaonkar in forum Samsung Galaxy Tab 2
    Last Post: 10-22-2015, 05:04 AM
  2. Replies: 4
    Last Post: 06-26-2014, 03:27 AM
  3. I'm not lucky at all
    By MetalxAssassinx in forum HTC One M8
    Last Post: 06-13-2014, 05:22 PM
  4. Where is the Google Navigation GPS icon?
    By Casey Cheung in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-10-2014, 12:24 PM
