1. rhynnian's Avatar
    Hello! I've tried googling to find help/other threads about this, and I've been able to find all of the problems I'm having individually, but the fixes for each issue are interfered with by the other problems... Any help would be incredibly appreciated!
    Model: SGH-I747
    Carrier: AT&T
    Unrooted
    So, as the title says, when I tried to factory reset my phone to give it to a friend, upon powering on it froze at the glowing Samsung screen, after the AT&T screen.
    I've tried powering into recovery mode, and it does briefly flash the "recovery booting" message, but then it either proceeds to boot up as normal and gets stuck on the Samsung logo, or just turns off again.
    I can get it into download mode, but Kies doesn't recognize my phone when I plug it in - I get a 'connecting to your device' message for a few minutes, then it tells me it wasn't able to connect.
    I'm not sure if it's normal or not, but when I put it into download mode it comes up with the screen "Downloading... Do not turn off target!!"
    The upper left corner reads:
    Odin Mode
    Product Name: SGH-I747
    Custom Binary Download: No
    Current Binary: Samsung Official
    System Status: Official
    Qualcomm Secureboot: Enable
    Any help would be greatly appreciated! I'm not worried about saving any files (obviously, as it was the factory reset that started all this), so I'm game for pretty much anything that might help.
    06-11-2014 12:05 PM
  2. Flashvetrin's Avatar
    Model: SGH-I747
    Carrier: AT&T
    Unrooted
    Odin Mode
    Sounds like you were in the middle of a flash using odin? ๐Ÿ˜ข and got a fail๐Ÿ˜ฆ.. is your device stock?? Do you have custom recovery?? Are you rooted? Can you still get into download mode?? ๐Ÿ˜ฎ do not worry reply and i can get u back in shape๐Ÿ˜†
    Sent from my MARCUS! using Tapatalk
    06-11-2014 12:14 PM
  3. rhynnian's Avatar
    I might have been! I'm kind of a newbie when it comes to fiddling with cell phones, though.
    It's stock and unrooted, and... I don't know what custom recovery is? I can get into download mode, yes.
    06-11-2014 01:23 PM
  4. Flashvetrin's Avatar
    Ok so what you need to do is go to either sams mobile or galaxy note 3 root.com and download the stock odin zip for your phone. Pay attention to the model number.. unzip it on your desktop put your phone into download mode start odin youll see a yellow box that will have a com port highlighted. Click on pda navigate to the extracted folder youll see a folder that ends in tar. Load that into the pda slot and hit start. And wait. This will flash the stock firmware back onto your phone..
    rhynnian likes this.
    06-11-2014 01:29 PM
  5. Flashvetrin's Avatar
    Ps dont fiddle no more๐Ÿ˜†
    06-11-2014 01:31 PM
  6. rhynnian's Avatar
    Well, it still freezes on the samsung logo, but I can access recovery mode now! Baby steps... Thank you!
    06-11-2014 07:43 PM
  7. Flashvetrin's Avatar
    What stock odin file did you download.. when you follow the steps do you see pass?? And after you reboot does it go into a mode that shows any with a hexagon spinning in his belly?
    Also after the flash unplug the phone from the pc..
    Post a copy of the name of the folder you downloaded i want to look at it. Also your exact model num.. ๐Ÿ˜Š
    06-11-2014 07:56 PM
  8. rhynnian's Avatar
    I downloaded this one Firmwares | SamMobile | Page 3
    But! I did manage to get it to work, I had to close out Kies and switch usb ports on my computer, one of those was messing things up apparently. After clearing the cache and doing a factory reset via recovery mode, it booted up like a charm.
    06-11-2014 09:09 PM
  9. Flashvetrin's Avatar
    Nice good for you๐Ÿ˜€๐Ÿ˜€๐Ÿ‘๐Ÿ‘๐Ÿ‘๐Ÿ‘
    Chow glad i could help..๐Ÿ˜†
    06-11-2014 09:17 PM
  10. thinksomuch's Avatar
    good,I might have been! I'm kind of a newbie when it comes to fiddling with cell phones, thank you
    06-12-2014 08:53 AM
  1. anyone prefer stock Samsung keyboard over SwiftKey keyboard?
    By CarrierPigeon in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-16-2014, 07:43 PM
  2. Samsung Tab 3 Lite Bricked help!!
    By androiddde in forum Samsung Galaxy Tab 3
    Last Post: 06-15-2014, 12:07 AM
  3. Galaxy Note 8 - Need some advice
    By aximtreo in forum Samsung Galaxy Note 8.0
    Last Post: 06-13-2014, 12:55 PM
  4. Unique "stuck in recovery" issue with samsung galaxy exhibit t599
    By cynthetism in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-11-2014, 09:32 AM
