1. PokeDroid's Avatar
    Hey, my google calendar events won't appear in the stock calendar. They did before and now they disappeared. It says in settings it's being synced but I can't see them. Also when I go to calendars it only says Samsung calendar
    06-17-2014 02:49 AM
  2. cpaight's Avatar
    Try re-downloading the Google calendar from the Play store.
    https://play.google.com/store/apps/d...droid.calendar
    06-17-2014 09:10 AM
  3. PokeDroid's Avatar
    I did that but I want to use the Samsung calendar stock. Should I just leave the google calendar installed and not uninstall it?
    06-17-2014 11:06 AM
  4. cpaight's Avatar
    Were your events showing up before you uninstalled it the first time? If so, that might be the problem.
    06-17-2014 11:38 AM
  5. GSDer's Avatar
    When you open the Samsung calendar, press the Menu button and select 'Calendars', does it show your Google calendar in the list? If not, select the 'Add account' button in the upper right corner and add it.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    06-17-2014 12:10 PM
  6. PokeDroid's Avatar
    It said it was added but it's not showing up
    06-17-2014 02:24 PM
  7. PokeDroid's Avatar
    Yeah they showed up before I Uninstalled it but when I did they disappeared
    06-17-2014 02:25 PM
  8. GSDer's Avatar
    Strange. I didn't have to do anything special; I didn't even install the Google Calendar app - the Google account just shows up in the list and the events show up in the calendar.
    06-17-2014 02:48 PM
  1. Samsung Galaxy Tab 3 recovery issues
    Last Post: 07-08-2016, 10:40 PM
  2. Rooted LG Motion Issues
    By Airfluff22 in forum Android 4.0 Ice Cream Sandwich
    Last Post: 06-29-2014, 11:08 PM
  3. Battery Draining (and heat up) issues?
    By mbressman in forum Sprint LG G2
    Last Post: 06-21-2014, 04:09 PM
  4. Picture Gallery Issue!!!
    By mrteach3 in forum Samsung Galaxy S4 Active
    Last Post: 06-19-2014, 03:31 PM
  5. Picture Gallery Issue!!!
    By mrteach3 in forum Samsung Galaxy S4 Mini
    Last Post: 06-17-2014, 08:19 PM
