1. mtlmuriel's Avatar
    Hello everyone,
    Before I freak out and return my phone I am hoping someone can help. I've had my Samsung Galaxy 3 for 8 months and it's been working without a problem. The last couple of days the battery has been draining rapidly and not recharging fast at all. After restarting a few times, there was no change so I backed everything up and did a factory reboot.
    Now the phone doesn't turn on at all. I have taken out the battery, waited, put it back and plugged it iin. There is nothing on the screen and it doesn't start when I press the power button.
    Can anyone help? I will leave it to charge until the shops open tomorrow... but I would prefer to save it rather then service it!
    06-17-2014 04:27 PM
  2. mhunter6378's Avatar
    Hello everyone,
    This is the S5 forum - but while you're here... When you say a factory reboot what exactly do you mean? Did you go to settings, backup and restore and do a factory data restore?
    06-17-2014 04:44 PM
  3. mtlmuriel's Avatar
    Ah, my bad, I'll repost unless you can help. Yes, it was a reboot from from the settings
    06-17-2014 05:04 PM
  4. mhunter6378's Avatar
    Have you tried to boot into recovery? Hold volume up, home and power buttons at the same time, you will feel a haptic feedback and when you see the samsung splash screen release the power button to boot into recovery
    06-17-2014 05:13 PM
  5. mtlmuriel's Avatar
    Just tried it. There was no feedback. I'm trying another charging cord, directly to my laptop. But I see no sign of life.
    06-17-2014 05:17 PM
  6. mhunter6378's Avatar
    Does the phone even respond to being plugged in, red led or anything?
    06-17-2014 05:29 PM
  7. mtlmuriel's Avatar
    Nothing, that's what's worrying me. It's weird that it happened after a restore. I'll leave it plugged in, and try the boot into recovery again later.
    06-17-2014 05:34 PM
  8. mhunter6378's Avatar
    Found this thread for you in the S3 forum, maybe it will offer you some help
    http://forums.androidcentral.com/sam...wont-turn.html
    Worse case scenario (or best depending on your perspective) may be a good time to upgrade to a new S5 Good luck getting this sorted out.
    06-17-2014 05:38 PM
  9. mtlmuriel's Avatar
    Lol. Might be time for an upgrade, but I am still under warranty... I was looking through that thread but I couldn't find anything about a case like mine. Thanks for helping me though!
    06-17-2014 05:43 PM
  10. ab304945's Avatar
    Try booting into download mode. Hold the volume down, home, and power buttons at the same time. And see if you can get into download mode. If you can then you can flash a stock tar with odin
    06-17-2014 05:53 PM
  1. How to add exchange account on outlook app?
    By boo516 in forum Ask a Question
    Last Post: 06-28-2014, 10:36 AM
  2. Periods added after multiple words in same text sentence
    By swistock in forum Samsung Galaxy S4
    Last Post: 06-20-2014, 04:36 PM
  3. LG G flex bug on organizing playlist music?
    By TapStrider in forum LG G Flex
    Last Post: 06-18-2014, 09:16 AM
  4. My lg g2 got brickked after hard reset using TWRP.
    Last Post: 06-17-2014, 10:33 PM
  5. How to remove the Top Symbol keys on keyboard
    Last Post: 06-17-2014, 07:13 PM
