Results 1 to 6 of 6
    Default SG3 won't turn on after a reboot
    Hello everyone,
    Before I freak out and return my phone I am hoping someone can help. I've had my Samsung Galaxy 3 for 8 months and it's been working without a problem. The last couple of days the battery has been draining rapidly and not recharging fast at all. After restarting a few times, there was no change so I backed everything up and did a factory reboot.
    Now the phone doesn't turn on at all. I have taken out the battery, waited, put it back and plugged it in. There is nothing on the screen and it doesn't start when I press the power button. The battery is still flat, it does not appear to be leaking or warped. I am trying to charge it with a second charger, but nothing is changing.
    Can anyone help? I will leave it to charge until the shops open tomorrow... but I would prefer to save it rather then service it!
  2. #2
    Default Re: SG3 won't turn on after a reboot
    Do you have access to another battery in order to eliminate that from the equation?
    If you take the battery out and connect the charger do you see the LED flash red very briefly?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    No other battery handy. But I did get the red light (stayed on for a few seconds) when I plug in without the battery.
    Does that mean the battery is kaput? Should I bother going to the Samsung Service Center, or just order a new battery?
  4. #4
    isdaako's Avatar
    Posts
    Global Posts
    831 Global Posts
    Not good. Considering the phone is under warranty you should consider that option. The quickly draining battery, were it caused by some app, should have been cured when you did the factory wipe. Perhaps you can find some friendly retailer nearby to allow you try before you buy another battery.
    Good luck.
  5. #5
    for my phone i had similar problem but not with battery draining out. just wont start
    I have posted seperately about this issue as well. I have a spare battery which didnt help in this case
  6. #6
    Quote Originally Posted by mtlmuriel View Post
    No, that check doesn't mean that the battery is kaput - it's just one more way to check to see if there's any activity on the phone.
    If there's a Samsung Service Centre nearby then by all means take it in.
    If there wasn't one my suggestion would be to get a new battery (the Rav 2250mAh battery has received some positive feedback in the forums.)
  1. Dark Lines on Bamboo Moto X
    By kansasandroid1 in forum Moto X (2013)
    Last Post: 06-20-2014, 04:52 PM
  2. Messaging app super slow, only on certain contacts
    By wocketpatch in forum HTC One M7
    Last Post: 06-19-2014, 11:43 PM
  3. LG G flex bug on organizing playlist music?
    By TapStrider in forum LG G Flex
    Last Post: 06-18-2014, 09:16 AM
  4. Any Clue How The Cover Open/Turn On Device Functions?
    By ScottyAG in forum ASUS MeMO Pad HD7
    Last Post: 06-17-2014, 08:08 PM
  5. SG3 won't turn on after factory reboot
    By mtlmuriel in forum Samsung Galaxy S3
    Last Post: 06-17-2014, 05:53 PM
