1. Beldkuhn's Avatar
    Hi, I am new and NOT technically I have the Samsung Galaxy S3. I have accidentally deleted all my photos off the phone. (not SD card). I have searched for them and of course they cannot be found can anyone help me please. I have tried to look for software but i am unsure what will actually work. My Hubby said something along the lines of i need to "root it"... Not sure how to do that either. Are my photos retrievable???
    06-22-2014 02:46 AM
  2. GSDer's Avatar
    Welcome to the forums!
    You can take a look at:
    http://www.wondershare.com/data-reco...-recovery.html
    http://www.easeus.com/datarecoverywi...y-software.htm
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    06-22-2014 06:19 AM
  3. Beldkuhn's Avatar
    Thank you so much, I am yet to try it, i am a bit nervous that it will kill my phone. I need to have my phones " drive mapped", Will i still need to do that with this software? Sorry for being so naive. Thank you
    06-22-2014 07:51 AM
  4. GSDer's Avatar
    Unless your phone is running a much older version of Android (4.0.4 IIRC) you can no longer do that - Google removed support for Mass Storage mode awhile back.
    I haven't needed to use either of those apps (they've been mentioned favorably in other threads) but they shouldn't require you to map the internal memory as a drive letter.
    In the future you may want to consider something like Cloud Drive http://market.android.com/details?id...uddrive.photos - it'll allow you to automatically backup your pictures/videos to the cloud (5GB free).
    06-22-2014 02:20 PM
  5. Mike Armitage's Avatar
    How or which way did you delete them..I done the same but found them in the MY FILES on the phone..Not sure where they were but have a good look on My Files...Hope it helps....
    06-22-2014 09:04 PM
  6. Beldkuhn's Avatar
    Thank you all so much, so far not having much luck, I deleted them in the main screen, got a bit sidetracked and it said one item selected.. Could have kicked myself. Is there anyone i can take it to to see if they can get them back for me? I need to map the drive... I do NOW have them on dropbox. I have looked through the My Files folder but it all seems like jibber to me...
    06-23-2014 01:19 AM
  7. GSDer's Avatar
    Did you try either of the programs that I mentioned?
    06-23-2014 11:53 AM
  8. Beldkuhn's Avatar
    Hi GSDer,
    I have tried both of the applications and still can not get any further with this.
    My model phone is the i9305 and comes up as not being compatible with the Wondershare software. It then prompts if I want to proceed, it then scans and stalls at 80%.
    The other software installed, but I can not see any drives or mapping for my phone to scan.
    So still no better off. hank you for your feedback and assistance.
    Belinda.
    06-29-2014 12:42 AM
  9. GSDer's Avatar
    Sorry. I'm sure Google had reasons for removing support for Mass Storage mode but that unfortunately pulled the rug out from solutions to this problem.
    You'll just have to take appropriate precautions in the future.
    Beldkuhn likes this.
    06-29-2014 02:22 AM
  10. Beldkuhn's Avatar
    Thank you so much for all your help ..
    06-29-2014 09:29 PM
  11. blisoachle's Avatar
    06-30-2014 11:03 AM
  1. Replies: 5
    Last Post: 10-18-2016, 10:25 AM
  2. Galaxy s4 charging very slow
    By Clayton Youngers in forum Ask a Question
    Last Post: 06-24-2014, 04:42 PM
  3. Galaxy S5 split sms message numbers
    By jtinker6171 in forum Ask a Question
    Last Post: 06-23-2014, 10:55 AM
  4. How to change Galaxy S5 default email app?
    Last Post: 06-22-2014, 01:45 AM
  5. Article: Spyware-bearing Galaxy S4 clone gets banned from eBay
    By Sergiusz Jasper in forum General News & Discussion
    Last Post: 06-22-2014, 01:33 AM
