Results 1 to 7 of 7
    Anomar Amundson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help me brick my phone!
    Odd request, I know, but my galaxy s3 was just snatched up by some punk kid. I'm wondering if I can brick it from my computer so he can't use it or access my personal data on it. I know that Google Play will let me remote download apps onto my phone from a pc, is there something like this I can kill the phone with?
  2. #2
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,272 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help me brick my phone!
    This article recommends "android lost" http://www.pcmag.com/article2/0,2817,2352755,00.asp and there's this which I don't know how much help it is. https://support.google.com/a/answer/173390?hl=en Good luck.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Much thanks :-) I'll give it a try and check in later
  4. #4
    cnotes2019's Avatar
    Posts
    Global Posts
    821 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was going to suggest that too but if that doesn't work I would definitely report it to your carrier ASAP so the person can't use it
    Sent from my iPhone using Tapatalk
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks guys but it seems those p options can't be done retroactively :-(
    I tried to call the service provider asap, but it was after office hours and it just kept sending me to a message to call back during office hours, so I'm planning to do that first thing tomorrow.
    Thanks anyway guys :-)
  6. #6
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,272 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Really? I was looking at Android lost and it seemed like you could use it retroactively. Disappointing if you can't.
  7. #7
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Apparently you didn't have Android Device Manager enabled on your device? You could track the location or remote wipe it.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  1. galaxy s5 sound help
    Last Post: 09-02-2014, 02:18 AM
  2. Replies: 1
    Last Post: 09-01-2014, 08:20 PM
  3. need help deciding my next phone suggestion much appreciated
    By sony android in forum Ask a Question
    Last Post: 09-01-2014, 08:09 PM
  4. Update killed my phonebook
    Last Post: 09-01-2014, 07:18 PM
  5. Please help me! Pulling my hair out
    By Justinkutzley in forum Ask a Question
    Last Post: 07-03-2014, 01:24 AM
