1. Trex Phire's Avatar
    Recently there was a firmware update.. After the update, I can no longer stay connection unless I am near a wifi spot, and if its secure, I have the password to be able to connect. Before this firmware update, I had no problems. No matter where I was, I was always connected... My fiance's phone stays connected no matter where she is, but mine wont.
    I have went through almost all the settings between her phone and my phone, and everything looks to all be setup the same. What could be the problem here?
    I have turned the phone off / on.. I have removed the battery, put it back in. Reset connections, etc. And it just wont stay connected unless I am near a wifi connection. Any help?
    07-05-2014 09:20 PM
  2. GSDer's Avatar
    Welcome to the forums!
    I'm not sure I understand your situation. Are you saying that Mobile data isn't working? You've turned it on, and the Settings screen and Status bar show that it's on, but you can't access the Internet?
    Or are you having some Wi-Fi issue that I'm missing?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    07-05-2014 11:31 PM
  1. Replies: 1
    Last Post: 04-12-2015, 10:29 PM
  2. T-Mobile Galaxy S3 with AT&T Software
    By Hassler Osorto in forum Ask a Question
    Last Post: 03-31-2015, 06:59 PM
  3. My Samsung Keyboard Has STOPPED Working!!
    Last Post: 01-24-2015, 02:18 PM
  4. Replies: 1
    Last Post: 09-02-2014, 01:07 AM
  5. problen with samsung galaxy s3 mini
    Last Post: 07-05-2014, 07:37 PM
