Results 1 to 4 of 4
    Exclamation 80% battery drained just in 1 hour! who could be worse than me?!
    this morning I woke up my phone was 100%, after an hour i went out to work, my phone's battery dropped to 33%. I was shocked! Because this is abnormal. My phone was quite alright yesterday (full battery could be used 1 day +) and i didn't update or install any applications.
    i checked the android system, it was only on for 6 minutes, so it shouldn't be using that much of battery.
    what happened to my phone?
  2. #2
    Default Re: 80% battery drained just in 1 hour! who could be worse than me?!
    Welcome to the forums!
    It's hard to tell what the problem was from the one data point that you included. Sounds like you had a runaway process, and rebooting the phone would have taken care of that.
    It's also possible that you had a weak Mobile data signal, which would go through power like the proverbial hot knife through butter. You could use something like SignalCheck Lite http://market.android.com/details?id...ignalchecklite to monitor the various signal qualities (cellular, mobile data, Wi-Fi) and see if any of those are responsible for your battery behavior.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Question Re: 80% battery drained just in 1 hour! who could be worse than me?!
    that's what I'm thinking as well. Because before it went crazy, a whole day work (8hour, no game play, only using a instant messaging chatting app) would only cost me about 40% battery, but today it suddenly becomes like this, I wouldn't consider it's caused by an old battery problem.
    I turned Flight mode on, turned off the phone and took out the battery, waited for 30s and put back in. the battery percentage suddenly increased from 21% to 35%. And now I'm charging with the Flight mode on. Let's see if it would be better
  4. #4
    check this out Guys, Solution works for me
    i install cm 11 for my neo v..bu battery drain fast...when i fully charged 100% at night...when i got up morning it's 70% battery standby
    SO here is the sloution
    connect your charger to phone
    then off the phone with out removing the charger
    (then phone automatically charging)
    then again on the phone with out removing the charger
    and let it to be charged 100%
    then see the battery works fine
    it's work for me....
  1. mobile standby eating all battery LTE data only service
    By george marcotte1 in forum Google Nexus 5
    Last Post: 01-14-2015, 12:48 PM
  2. my phone mutes on my pocket when someone calls me
    By remos2010 in forum HTC One M7
    Last Post: 07-22-2014, 02:50 AM
  3. Need help in fixing my nexus 5
    By umarey in forum Google Nexus 5
    Last Post: 07-16-2014, 09:11 AM
  4. What's *WAKELOCK* It's killing my battery!
    By AlfBriggs in forum Ask a Question
    Last Post: 07-11-2014, 09:11 AM
  5. Asian Writing in Pop Up Screens :(
    Last Post: 07-11-2014, 09:02 AM
