1. RAvEcREAToR23's Avatar
    Sometimes system sounds just muted shown here https://www.dropbox.com/s/dmoxtokt6t...0-23-14-05.png and slider not works so no way turn back on, restart phone helps but ir is not good way to restore... Can someone help?
    07-20-2014 03:25 PM
  2. GSDer's Avatar
    I can't see your screenshot - is the System slider greyed out?Are the other sliders working as expected?
    If you boot into Safe mode http://support.verizonwireless.com/s...ase.html/59242 do you have the same problem?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    07-20-2014 10:34 PM
  3. RAvEcREAToR23's Avatar
    Other sliders works normaly... Not tryed go safe as restart is like fix it for some time. But will go try safe mode... And slider greyed and looks like when muted turned off sounds just that no way slide it... (funny that system go to normal from no reason when i write this reply i did nothing)
    07-20-2014 11:31 PM
  1. Replies: 1
    Last Post: 04-03-2015, 01:20 AM
  2. no sound with video sent by text
    Last Post: 09-04-2014, 10:11 PM
  3. Galaxy Exhibit Is Not Making Any Sound
    Last Post: 09-04-2014, 10:09 PM
  4. Lockscreen/Sound Issues
    By zebra23 in forum LG G3
    Last Post: 07-20-2014, 05:28 PM
  5. Using the Note 2 With Chevy's My Link Infotainment System
    By ClaudiaP in forum Verizon Galaxy Note 2
    Last Post: 07-20-2014, 12:18 PM
