1. arwa13's Avatar
    Every time I try to make a call or receive a call - after few seconds - people stop hearing me and it gets disconnected. I can't remember the last time I had a phone call that lasted for more than a minute. I sent my phone to be prepared multiple times and they don't seem to know how to solve the problem - or they solve it and the same problem reoccurs.
    I really need to know if there is a hope to fix this problem. I used to think the main problem is with the service/reception area, but sometimes I'm in a place with full reception and it keeps disconnecting.
    My mobile data works perfectly fine, so I know it's not a SIM problem and making phone calls on other devices using the same SIM seems to work.
    If this problem is already discussed on this board please provide me a link, I can't find a solution all over the internet.
    RobertP1 likes this.
    08-10-2014 05:35 AM
  2. GSDer's Avatar
    Did this ever work?
    Does the same thing happen if you use the Speakerphone?
    What about if you try a set of headphones with a few mic?
    Bluetooth headset?
    Have you tried booting into Safe mode? http://support.verizonwireless.com/s...ase.html/59242
    If you record a video and talk or play music in the background, does the audio show up consistently in the playback?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    08-10-2014 03:01 PM
  3. arwa13's Avatar
    I tried everything. Nothing happened. It keeps disconnecting my calls. I don't think it has to do with the microphone or the speaker, because people on the other end can hear me for the first few seconds, and then they stop and the call is automatically disconnected. I tried a different SIM, I tried with speakerphone and headphones. Nothing is working.
    08-25-2014 03:15 PM
  4. mrsmumbles's Avatar
    Have you tried enabling the setting "power button ends call"? With that on, the call shouldn't end until you press the power button.
    08-25-2014 03:26 PM
  5. GSDer's Avatar
    I tried everything.
    You tried Safe mode and it didn't make any difference?
    And when you tried recording a video the audio was present the whole time?
    If you turn Wi-Fi off and Mobile data off does the same thing happen to the phone call?
    Have you tried a Factory Reset?
    08-25-2014 09:58 PM
  6. Jafar dahodwala's Avatar
    Please help me?
    In my karbonn k9 viraat, call automatically cuts after few seconds or few minutes. When the call is on the speaker its works perfect, and my mobile data is also running perfectly but when the call is not on speaker it cuts again again.
    Please reply if anyone has the solution
    09-14-2016 04:11 AM
  7. IHaveQuestionsYouHaveAnswers's Avatar
    Hi. I have been facing similar problem with my phone as well. However, my case is particularly curious for a couple of reasons:
    1. This phone was used by my father for at least a year before facing similar issues.
    2. I fave been using the this phone and this particular number (which I ported from Bangalore) in Noida. However, when the sim was "roaming" in Kerala for a week this issue was non-existent. The minute I landed in Delhi calls started getting cut 3 seconds in.
    Ergo, I am not able to figure out if it is a phone problem or a sim problem or some random setting that is messing with me.
    11-07-2016 11:40 PM
  1. Any good video calling apps?
    By xonq in forum Samsung Galaxy S4
    Last Post: 08-10-2014, 11:35 PM
  2. The battery on my Phone is going out way too fast.... Help!!? :(
    By blahblahblahxoxox in forum Ask a Question
    Last Post: 08-10-2014, 03:28 PM
  3. Webpage is not available.
    Last Post: 08-10-2014, 02:01 AM
  4. Wifi Turns Off after Reboot
    By MikeB17 in forum Samsung Galaxy S5
    Last Post: 08-10-2014, 01:37 AM
  5. Galaxy Victory powers down moments after turning on; need help ASAP!
    By Nathaniel Kaetzel in forum Ask a Question
    Last Post: 08-09-2014, 10:01 PM
