1. Mohammad Shebaro's Avatar
    Guys when i put my samsung galxy s3 on charge the battery level drecreases instead of increasing//// oneday i left my phone 10 oclock p.m. at charge and it was 5% when i woke up in the morning at 8 oclock a.m. the battery was 8 %. I have changed the battery and even my charge 4 times and it's useless!!! I tried downloading apps that maybe fix my problem like downloading battery doctor ----->>>> useless again same problem. Pleaseeeeeeee helppp me
    08-10-2014 12:56 PM
  2. GSDer's Avatar
    Welcome to the forums!
    Have you tried turning the phone off completely and connecting the charger? You should see a graphic showing the current battery level and charging activity. In that configuration it should only take about two hours to fully charge the phone.
    If the phone isn't charging properly in that configuration then you need to try a different charger AND cable. If there's still a problem then it's likely an issue with the micro-USB port on the phone - your options are to clean it, get it replaced or try a wireless charging solution.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Mohammad Shebaro likes this.
    08-10-2014 02:54 PM
  3. Mohammad Shebaro's Avatar
    Hi bro I tried charging my samsung galaxy s3 with a charger of samsung galaxy s4, my phone charged properly and fast and the battery lasts longer. Will it damage my phone if i do this?
    08-10-2014 05:11 PM
  4. Mohammad Shebaro's Avatar
    And why my phone worked on the charger of samsung galaxy s4 i need to know and thankss
    08-10-2014 05:15 PM
  5. GSDer's Avatar
    No, it won't damage your phone.
    Sounds like whatever charger/cable you were using earlier went bad - it happens.
    08-10-2014 11:51 PM
  6. Mohammad Shebaro's Avatar
    Thanks gsder
    08-11-2014 02:59 AM
  1. Samsung Galaxy Ace - Security Warning pops up constantly?
    Last Post: 04-01-2015, 11:50 AM
  2. Replies: 1
    Last Post: 04-01-2015, 12:12 AM
  3. deleting pictures from picasa album in galaxy
    Last Post: 08-15-2014, 02:53 AM
  4. Galaxy S5 all sensors broken...
    Last Post: 08-10-2014, 01:17 PM
  5. Replies: 0
    Last Post: 08-10-2014, 12:36 PM
