Results 1 to 2 of 2
    shaioz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default network not registered
    i updated my phone to 4.3 .. since then i cant receive or make calls .. it shows the signal strength but when i call it says not on registered network .. when i pull the notification bar down .. in the bottom it says emergency calls only .. i tried other sims also but the problem is there
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: network not registered
    Welcome to the forums!
    You received an OTA update, or you manually updated?
    Sounds like something got buggered up. Have you tried a Factory Reset? As well as wiping the system cache in Recovery mode?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  1. How make S5 NOT show my number on calls......
    By dkperez in forum Samsung Galaxy S5
    Last Post: 09-08-2015, 10:28 AM
  2. Subscribed Google Calendar's not syncing with EVO 4G LTE
    Last Post: 08-29-2014, 05:18 PM
  3. Home Wifi does not turn off
    Last Post: 08-29-2014, 04:42 PM
  4. apps lingering on download and will not install to device
    By badger2727 in forum Ask a Question
    Last Post: 08-29-2014, 04:00 PM
