Why won't my Samsung S3 turn on?
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Re: Why wont my Samsung S3 turn on
Welcome to the forums. Perhaps the battery is defective? Take it out and on a flat surface, try to spin it. If it does, it is bulged and needs to be replaced.
Tanner Wooldridge
it doesn't seem to be the battery. ive changed the battery. does the same thing.. I can get it to go to the download mode. when I hold the power button down it does pop up a battery then shuts off.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Can you reboot into recovery? That would be the same button combo except for volume up instead. Once there, try a cache wipe.
Nanran21
