Samsung Galaxy S3 stuck on TWRP bootloop, how can I fix it?
  • Start date Start date
A
AC Question
The other day I got my IPhone fixed so i decided to wipe my android and put it away for later, but in doing this I wiped the operating system and now when i try to turn it on it starts up normally but then goes to TWRP loading screen and just stays there. I cannot enter download mode it just takes me back to TWRP.
Re: Samsung Galaxy S3 stuck on TWRP bootloop
try plugging in the usb download cable (not connected to anything (sounds strange i know)) then try boot to download mode. Had the same problem with my old s3. you will probably need odin and cf autoroot if you manage to get to download mode.
kuzmaj05
