1. Ashton Huff's Avatar
    I have a working solution for all metro pcs customers that are having problems downloading from the Google Play Store. Go to settings, click more. Go to access point names. Press+ to make a new one. Click name make it whatever name you want. Change APN to fast .metropcs .com.
    (no spaces). Scroll down to mmsc change that to https://metropcs .mmsmvno .com/mms/wapenc.
    (No spaces)
    Save the access point then select that access point to use. Then Walla!!!! No more play store downloading issues
    04-17-2017 09:57 PM
  2. B. Diddy's Avatar
    Thanks for the tip! Here are the full APN settings, if anyone else needs them: MetroPCS APN Settings – Step by Step Configuration
    04-18-2017 03:45 PM
  3. Ashton Huff's Avatar
    No problem @B. Diddy. If the problem still occurs let your battery fully drain, charge your phone, and turn it back on
    04-20-2017 09:27 PM
  1. Slow download speeds with Google pixel xl on sprint lte network
    By AC Question in forum Google Pixel & Pixel XL
    Last Post: 04-20-2017, 10:03 PM
  2. Youtube sound cuts in and out while playing on Android.
    Last Post: 04-17-2017, 09:30 PM
  3. My phone is not charging at all?
    Last Post: 04-17-2017, 09:27 PM
  4. Get a message i dont have enough space to download
    Last Post: 04-17-2017, 08:45 PM
  5. Galaxy S7 Edge can't send or receive MMS with WiFi enabled
    By Icespot in forum Samsung Galaxy S7 edge
    Last Post: 04-17-2017, 08:31 PM
