NoMod
Here's the lowdown on cables and charging the S4.
Not all cables are made alike, but for the most part, they can be interchanged, as long as you understand a few things. The facts are
-micro USB plugs are standard in size and shape. But the wiring from one to another is not entirely standard. Some conductors are deliberately crossed or shorted. Some phones use this to recognize proprietary charging systems and to know the current and quality of the charge, and how to handle it.
Furthermore, it's not just the quality of the cable. It's the combination of cable and charger. You will get different results by swapping wires and wall- and car-chargers.
The Samsung Galaxy S4 comes with a 2-amp charger and its "original brand" high-quality cable. This combination will provide optimum charging time. Most other combinations will work, up to a point. But just as a lower powered charger will take longer to power up a drained battery, so too will a different or inferior cable, which is simply not capable of carrying the full 2 amps of power, even if plugged into the Samsung charger. It has to do with pin configuration, shielding, quality of construction, etc. The length and thinness of the wire has absolutely no effect, unless we're comparing a 2-foot wire to a 200-foot one.
There are plenty of apps that measure and display charging current. It's easy enough to see what I'm talking about. And there are lots of technical articles inn the subject omg the 'Net.
