Re: Samsung S4's Micro USB to Standard USB cablek
After reading through this thread, the primary lesson to be learned seems to be, don't try to use crappy after-market USB cables with your phone (or anything else, for that matter). The weight of evidence appears to substantiate that good-quality cables will work fine.
IMHO, this has nothing to do with the "quality" of the cables. It has to do with "differently made" cables.
Here is my story:
Bought "original" Samsung microUSB cables for S4 off of eBay. Total BS.
The real, original cables that come with the box have a larger hole on the microUSB side, and at least on my cable, the white one that comes with the S4, it only has 4 pins, due to some funky Samsung reason, which may include what has been previously explained before. IMHO, the reason they do this though is to actually protect the device from other weirdo chargers that could damage the phone, since the S4 does in-fact quick-charge at 1900mA vs many other devices that work off of only 1000mA.
Now, I am worried about using any cable than the original one because my cousin damaged their microUSB jack on the S4 using aftermarket cables. Think about it.. all those cable that are a "tight fit" are REALLY TIGHT. you have to push in and pull out the cable with several times the force needed to pull out the original cable. The original cable pulls out VERY easily in comparison.
Why does this matter? Well, not only are you being forceful with the microUSB jack on the Samsung S4 by pulling the cable in and out but... lets say you drop it, the cable gets yanked on, you accidentally pull the device further than the cable length, or whatever.. When that happens, using the original cable, the cable could just pull out. On the other hand, other cables put a lot of stress on the little tiny connector inside the jack. Over time, this could kill the jack.
Now about charging speed, I did get a Samsung "lookalike" cable (probably fake) that did in-fact charge directly from the original Samsung charger at 1900 mA. HOWEVER, in other scenarios, it didn't perform exactly the same. One example is that, using a USB cord extender, the original cable actually lost power only getting like 900 mA, while the aftermarket one got 720 mA through the same USB extension cable. I tried this several times back and forth just to make sure and all tests were identical, showing different performance for both cables.
Why does this matter? The aftermarket cable was only 3ft, so I HAD TO use the USB cable extension (a nuisance in itself). Not only that, if I can't make sure the cable is 100% safe, I fear that over time, if my S4 isn't getting the right or consistent juice, other problems will develop. This happened with my old LG (also Korean) phone, where the screen would go all nuts until I unplugged it, a phenomena that I think ultimately damaged my phone.
So.. What am I irate about now? I CANNOT FIND THE ORIGINAL SAMSUNG CABLES (just like the one that came in the box) FOR SALE (on their own) ANYWHERE!
I thought I found one, but when it came in the mail, it wasn't the same one pictured in the listing! Instead of having the grooved little sheath thing that protects the connection between the actual connector and and the actual cable, it was just a smooth tube... basically, I got scammed again.
However... One still get the original cable... HOWEVER, it must be purchased with the adapter as well (and probably directly from SAMSUNG or and authorized retailer) for the humble price of $39.99! They don't sell the cable separately on their site. Whaddaya know, even the link their tech support chat sent me was for the cable AND charger... Well...... I HAVE 3 SAMSUNG CHARGERS ALREADY. I DON'T NEED ANOTHER STINKING CHARGER. Just a simple, genuine SAMSUNG, USB cable... Just like the one that came in the box and I'll be happy thankyouverymuch.
Oh yeah, and eBay sellers, don't send cables that don't look like the ones in the picture... And if you are selling a REAL S4 cable, go ahead and post macro pictures of the end of the microUSB connectors and call out all those other fake sellers. Thanks.
Have a nice day people looking for official S4 cables.
