dterrab
Hey, I am having the same problem. I did same things but problem is still there. Was your problem solved? It would be veary helpfull. Thks!
Hi there,
I have exactly the same problem! I try tapping the wi-fi icon from the drop down and it refuses to enable I have the same problem with the wi-fi hot spot too! Funnily enough the blue tooth icon works fine. Turned the phone on and off but hasn't resolved the issue. This bug just appeared out of nowhere today, not sure if this is covered under any samsung warranty? Terrible bug this is.
