Results 1 to 8 of 8
    Ashleigh O's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Put Samsung Galaxy S4 Active in shallow water, screens not working but everything else does.
    So i put my new samsung galaxy S4 Active in shallow water today and i made sure everything was pushed down and shut so no water gets in, but while taking the photo the screen went black so i took the battery out and dried it now my phone is in rice. is there any way to fix this problem?
  2. #2
    NoNexus's Avatar
    Posts
    Global Posts
    309 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Put samsung galaxy S4 Active in shallow water, screens not working but everything else does.
    how new? take it back.
    short of that, leave it in the rice for a day or two and see what happens
    Ashleigh O's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    its only i have only had it for 4 days, it turns on and its just the screen but if i put it on an angle it you can kinda see the screen its like it has been put on the lowest brightness setting.
  4. #4
    NoNexus's Avatar
    Posts
    Global Posts
    309 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Take it back must be a crack or improperly sealed case
    sent from my DROID Eris, made by Nokia, powered by iOS 7 via BBM
  5. #5
    gravatos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its defective likely, or its just stuck in teh underwater mode (only able to take pictures).
  6. #6
    moody1940's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Put Samsung Galaxy S4 Active in shallow water, screens not working but everything else does.
    Why did you put the phone in water?
    Sent from my SAMSUNG-SGH-I537 using AC Forums mobile app
  7. #7
    metle_geek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you make sure all of the connections were snapped in? Theres one under the camera that will let water in if its not snapped
    from my wonderfully rooted gs4 woot
  8. #8
    metle_geek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you had to dry the battery you had a bad seal that rubber seal is what keeps water out its either from the battery door or you didnt cover a port with a flap either case congradulations you now have water damage
  1. Replies: 15
    Last Post: 07-26-2014, 11:30 AM
  2. AT&T galaxy s4 active to tmobile prepaid?
    By felixa123 in forum Samsung Galaxy S4 Active
    Last Post: 03-28-2014, 09:16 PM
  3. Replies: 7
    Last Post: 01-31-2014, 01:29 PM
  4. Galaxy S4's Camera-Transition animation bug finally gone after update
    By Sanjay Chandra in forum Samsung Galaxy S4
    Last Post: 01-05-2014, 05:09 AM
  5. Zeki 7" Tablet TBDG773 Working Root, need a working recovery please?
    By Infamous One in forum Misc. Android Tablets
    Last Post: 01-05-2014, 01:30 AM
