1. phositadc's Avatar
    Anybody know if it will have one? The S3 mini did NOT.
    05-30-2013 10:12 AM
  2. friedtators's Avatar
    most do not
    check on noLed in the play store. it works i use it
    05-30-2013 10:28 AM
  3. phositadc's Avatar
    Confirmed that it does NOT have a notification LED. Samsung Galaxy S4 mini Review. Too bad. Does it really take up so much space that they can't fit it into the smaller device? I'm a bit disappointed.
    06-04-2013 10:29 AM
  4. jmike67's Avatar
    The verizon version of the s4 mini does have led notification light. It also has 16gb internal memory not 8 gb. It is an excellent, fast phone.
    12-26-2013 07:11 PM
  5. mdawdy's Avatar
    Mine from Rogers [Canada] came with 16 Gb. Where is the LED? Can you post a pic or a link? Thank you,
    12-26-2013 09:40 PM
  6. jmike67's Avatar
    Notification LED?-image.jpgIt's to the left of the ear speaker, where it is normally on the s4.
    axllebeer likes this.
    12-27-2013 01:04 PM
  7. jmike67's Avatar
    Go to settings, display, led indicator and make sure notifications box is checked.
    12-27-2013 01:07 PM
  8. mdawdy's Avatar
    ... It's to the left of the ear speaker, where it is normally on the s4.
    Thank you for the pic, and the Settings info. This confirms that it is not on my S4 mini.
    12-27-2013 06:37 PM
  9. CrazyTwitterFreak's Avatar
    The S4 has a notification LED but the S4 Mini does not have one.
    01-10-2014 10:09 AM
  10. mdawdy's Avatar
    See posts #4 and #6 above for a version of the S4 mini that does have the notification LED, including a pic of it.
    01-10-2014 06:18 PM
  11. Felderburg's Avatar
    I have a Verizon S4 mini, and it has a notification LED. Under the settings, it is in Display -> LED Indicator. It has options for a red LED lighting for battery related things, and a blue one lighting for missed calls / messages / etc. (it also lights up green when the phone is fully charged). All these notifications are for when the screen is off; I guess they assume you will be reading the actual notifications if the screen is on.
    01-13-2014 11:37 AM
  12. UJ95x's Avatar
    It's already been stated that it's only on the VZW version, not on the others. OP doesn't have a VZW one...
    01-13-2014 11:44 AM
  13. axllebeer's Avatar
    Incorrect. I have the Sprint version and it's also on mine. U. S. only perhaps?
    Posted via AC App from my S4 mini WITH an LED CrackLight ;-)
    05-27-2014 12:55 AM
  14. txgirl79's Avatar
    I too have LED notifications and setting options on my mini, and I'm with AT&T.
    06-07-2014 06:03 AM
  15. AsREDaS's Avatar
    Im in uk and while mine doesnt have the led notification light on the front, I can however set the flash on the back of the phone to 'flash' when a notification comes in. You can set it in message settings.
    06-09-2014 12:42 PM
  16. snuffdigital's Avatar
    I know for a fact that the Sprint version of the s4 mini has it. I ordered the Verizon version for myself after seeing that and should be getting that tomorrow and I can't wait. It was a feature I missed having.
    I've read countless places and reviews that say the international/some versions in general do not always have the notification LED light. Which knowing Sprint's had it and wanting one/that for myself on Verizon, that had me initially confused for if all companies in the US had the LED feature. But as others have attested it seems the LED indicator has been seen in most US models.
    06-15-2014 11:16 PM
  17. snuffdigital's Avatar
    Sorry for the double post but I made a video showing the different LED colors.
    I specifically have the SCH-I435 model of the s4 mini and Verizon is my carrier (US).
    07-09-2014 06:05 PM
  18. mrgender's Avatar
    to AsREDaS ...
    my s4 mini doesn't have a notification led on the front, nor does it have a message -> settings option to flash the camera lite on the back upon receipt of a message as you indicate. my phone is running android 4.4.2 and I'm in Canada.
    see my post in this same s4 mini subforum under topic "S4 Mini without Notification LED" for what I did to replace led notification.
    04-28-2016 01:23 AM
  1. Notification LED now available for Captivate
    By NeilQ in forum AT&T Captivate
    Last Post: 08-16-2010, 10:30 PM
  2. Replies: 0
    Last Post: 07-26-2010, 03:59 PM
  3. Anyone else's notification LED stop blinking after a while?
    By Jasonrj in forum Verizon Droid Incredible
    Last Post: 05-07-2010, 07:41 AM
  4. Notification LED
    By Justin89t in forum Verizon Droid Incredible
    Last Post: 04-21-2010, 11:36 PM
  5. Notification LED
    By manningfan10 in forum Motorola Droid
    Last Post: 03-29-2010, 06:50 PM
