1. rene 1's Avatar
    I have had my galaxy s4 mini (gt-i9190) for less than a week and today when I got a call I couldn't hear anything from the otherside. Than laterwhen I tried to listen to my music, no sound came out both speaker and headphones. lastly no sound comes out of tapping and voice searching. I've top the volume in every setting, restarted my phone, tapped my phone on the back and restarted in factory mode. I'm a bit panicking and I'm thinking of returning it and getting a new one, but before doing that I was wondering if I could do anything before doing so. Oh and I think it's not hardware because ( or maybe it is I'm not an expert) it does make a static sound, the one that you get from a radio in the wrong channel, and in occasion get a high pitch (but low sound) sound. Please help guys thanks
    11-21-2013 05:12 PM
  2. lavaboy's Avatar
    01-19-2014 08:14 PM
  3. mdawdy's Avatar
    Are you familiar with the volume up-down key on the left side edge of the phone? It is possible, with the phone is in your pocket [or wherever], that the volume down will get pressed. Happened to me a couple of times.
    01-19-2014 10:00 PM
  4. cezza180's Avatar
    Hey
    I had the same problem with my phone, then i went to
    -->settings
    --> my device
    --> accessibility
    and theres this part called hearing, and one of the tick boxes are "turn off all sounds"
    if that's ticked then that could be what is causing the issues
    Hope this helps
    Jaci Vennix likes this.
    01-26-2014 08:02 PM
  5. Jaci Vennix's Avatar
    Hey Cezza, Thank you so much as it looks like I ticked that box and lost my sound...lol I was having a heart attack thinking I have stuffed up my phone. This site is awesome as I just fall onto it by mistake. Thank you so much again for your help
    05-17-2014 11:36 PM
  6. esers178's Avatar
    Yeah this happened to me too but this didn't work I just turned it off and back on and it worked
    06-30-2014 09:55 AM
  7. Lily-Ann's Avatar
    Hi, this is going to sound strange, but the solution for me was to remove the 1 before all area codes. Even when making a long distance call, I have to remove the +1, and let the operator transfer the call for me automatically (there's a prompt saying that long distance charges may apply...) but after that it works. I've had the phone for two months and have always included +1 when calling, but for some reason the sound just doesn't work anymore if I dial +1 first.
    (I live in Ottawa, Canada with a Toronto number so all calls for me are long distance/roaming). Hope this can help someone!
    07-13-2014 07:27 PM
  8. kakamai's Avatar
    I am having the same problem compounded by the constant headphone sign even when the headphone is not attached to the handset. Worse! the headphone doesn't get attached at all. Please help!!!
    09-11-2014 02:08 AM
  9. bolotkanov10's Avatar
    I have had my galaxy s4 mini (gt-i9192) for less than a week and today when I got a call I couldn't hear anything from the otherside. Than laterwhen I tried to listen to my music, no sound came out both speaker and headphones. lastly no sound comes out of tapping and voice searching. I've top the volume in every setting, restarted my phone, tapped my phone on the back and restarted in factory mode. I'm a bit panicking and I'm thinking of returning it and getting a new one, but before doing that I was wondering if I could do anything before doing so. Oh and I think it's not hardware because ( or maybe it is I'm not an expert) it does make a static sound, the one that you get from a radio in the wrong channel, and in occasion get a high pitch (but low sound) sound. Please help guys thanks
    01-05-2015 06:56 AM
  10. s4minispeakerproblems's Avatar
    Hi,
    I had the same problem and this was the top result on google so I thought I would add my 2p as the more info the better right?
    My problem:
    I had sound with headphones and when making a call - but not on loud speaker. So no sound on youtube etc but most importantly no alarm!!!
    In my case I fixed it by taking off my case and quickly tapping the speaker module bit at the bottom of the phone (below the battery, it had two horizontal holes on the left hand side) with the end of a plastic knife.
    I hope this helps someone! Thanks to everybody involved in the thread.
    04-20-2016 06:34 AM
  11. s4minispeakerproblems's Avatar
    Hi,
    My problem:
    04-20-2016 06:34 AM
  1. S4 + KB + Mouse for field notes, data collection?
    By dhdoyle in forum Samsung Galaxy S4 Accessories
    Last Post: 04-20-2015, 07:35 PM
  2. Is there an easy way to reinstall jellybean......
    By Tim1131 in forum ASUS MeMO Pad HD7
    Last Post: 11-30-2013, 12:25 PM
  3. S4 mini not running smoothly after ROOT?
    By MichalDubsky in forum General News & Discussion
    Last Post: 11-22-2013, 02:38 PM
  4. Which is faster with updates?
    By Continuum88 in forum General News & Discussion
    Last Post: 11-22-2013, 10:43 AM
  5. Replies: 0
    Last Post: 11-21-2013, 03:47 PM
