1. Lee Davies2's Avatar
    Have only had my s4 mini couple days and at first thought was imaging this.
    When ever I use the Samsung keyboard to type (my other phone is the s3 mini) now let's say I start with "thanks" select it from predicted words then go into 123 sym select a number. Now with the s3 if I'd select thanks go into numbers all I would do is select my digit and come out. But in the s4 have to select thanks twice. Once in the qwerty and again in the symbols otherwise if I don't select 2nd time there will be no space.
    Hope you can make sense of it. ....?
    02-23-2014 05:54 PM
  2. Golfdriver97's Avatar
    I think I get it. It may be a bug in the keyboard app. You can try a different one from Play. Google has one for free and it works well.
    02-23-2014 08:23 PM
  3. Shelter7's Avatar
    I used Google`s keyboard for almost a year, on different Android-based gadgets, it`s the most reliable solution, and besides it`s free. If you don`t like it, you won`t regret spending any cent on it
    Golfdriver97 likes this.
    02-24-2014 08:16 AM
  4. Shelter7's Avatar
    02-24-2014 08:18 AM
  5. steviecapt's Avatar
    try swiftkey, its available on google playstore, its the best keypad ive tried
    Shelter7 likes this.
    02-24-2014 12:27 PM
  6. Shelter7's Avatar
    I downloaded it, let`s see what it`s able to do
    02-25-2014 11:56 AM
  7. Lee Davies2's Avatar
    Thanks for all the advice just downloaded the Google one and using for 1st time have to say having the not the $ on 1st is a result. Cheers
    02-27-2014 08:19 AM
  1. Samsung Note 3 unresponsive touch screen fingers (solved)
    By hshaltout in forum Samsung Galaxy Note 3
    Last Post: 07-05-2016, 03:56 PM
  2. [EE] Can I root my S4? [Noob] [Help]
    By Vayper in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 04-21-2014, 08:00 PM
  3. Help for new tablet
    By jbeats226 in forum General News & Discussion
    Last Post: 02-24-2014, 12:42 PM
  4. Using an SD card with CM-11
    By petalmasher in forum Android 4.4 KitKat
    Last Post: 02-23-2014, 08:38 PM
  5. Texting gif's help! (1mb file size limit, need solutions)
    By rebel2401 in forum General Help and How To
    Last Post: 02-23-2014, 07:38 PM
