1. Sonyaddd's Avatar
    Ok so a few days ago my samsung s4 fell into the toilet. It was still on when I took it out of the water then it turned off but first a screen appeared which said something about either the SD or sim card. I have dried my phone completely and it is not water damaged but every time I press the on button it buzzes, then the samsung screen appears and then it turns off again. This happens over and over again until I take the battery out. So basically my phone is not working and I am stuck on what to do. Please help!
    03-30-2014 08:52 AM
  2. dpham00's Avatar
    There could be internal water damage. You can try to put it in a box of rice for a few days, some people have had luck.
    If you have phone insurance then it should be be covered though you may have to pay a deductible
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-30-2014 08:58 AM
  3. Lee Davies2's Avatar
    Look on YouTube how to completely dissemble s4 believe it or not it's easy as 1,2 3 only hard part for me were the screw's. There is a connection which connects the screen to the motherboard. First time I put phone back together I did not put this on properly thus getting exact problem you have. Could be water in connection
    04-04-2014 11:45 AM
  1. Can apps be moved to SD card on HTC One (M8)?
    By hdradaza in forum HTC One M8
    Last Post: 11-19-2014, 03:00 AM
  2. (App Request) Samsung Galaxy Tab PRO 8.4 Watchon Apk
    By Rakista301 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 04-01-2014, 01:44 AM
