1. snoppy92's Avatar
    recently i have been having problems with my phone it keeps losing battery power fast and i have taken off all apps that drain power but it still loses power and also when i turn my phone off it just goes to white screen plz help
    07-14-2014 02:23 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! A few things to try:
    1. Try a new battery. A quick test of your old battery is to remove it, lay it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle, which is bad.
    2. Unmount the SD card (Settings>Storage), remove it, and reboot. A corrupt SD card can cause problems.
    3. Review this guide: http://forums.androidcentral.com/amb...ving-tips.html
    4. If all else fails, try a factory data reset.
    07-14-2014 03:56 PM
  3. mdawdy's Avatar
    The newest version of CleanMaster has a list of about 50 Apps that can be disabled if you are not explicitly using them. I have disabled all but about three.
    07-14-2014 07:23 PM
  1. How is Android Wear impacting your phone battery life
    By ChuckG73 in forum Android Wear
    Last Post: 03-05-2016, 12:40 PM
  2. unlocking effect problem
    By Naser Bandora in forum Ask a Question
    Last Post: 02-27-2015, 01:21 AM
  3. Phone is slow. Major lag
    By Dharma Jairam in forum Samsung Galaxy S5
    Last Post: 07-14-2014, 05:56 PM
  4. Anyone else have problems with the new update?
    By Nikki Hoover1 in forum Ask a Question
    Last Post: 07-14-2014, 01:54 PM
  5. Replies: 1
    Last Post: 07-14-2014, 01:08 PM
