Results 1 to 2 of 2
    mdawdy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Three Questions About Battery Doctor
    Phone is not rooted.
    1. So i press the spinney thing on the battery doctor widget and it says "3 apps closed prolonged power by 34 minutes", perhaps with different numbers. How can i determine which apps were closed?
    2. It appears that Android may be re-starting the same apps? So is power really being prolonged?
    3. The battery remaining percent displayed on the widget is usually greater then the percent displayed in the app. It seems the app does not update the widget often enough. Is there a way that i can force the app to do the update?
    Thank you,
    Mick
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,040 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Apps Terminated By Battery Doctor
    It really depends on the app. But apps in standby should have little affect on the battery.
  1. YouTube Official app issues, Video freezes and Multi-window mode not working
    By Jahanzeb Khalid in forum Samsung Galaxy Note Pro 12.2
    Last Post: 09-03-2014, 01:12 PM
  2. Replies: 3
    Last Post: 08-31-2014, 12:19 PM
  3. Galaxy S3 Sudden Rapid Battery Drain
    Last Post: 08-31-2014, 01:10 AM
